What does the loom do? I though most of the time the ones in the guards were to do with headlights and indicators.
I've lost my indicators and a couple of other little bits. Headlights are still ok and rest of the car is running as per normal. Chris is sorting it out tomorrow and I got some prices on some new rubber for the fronts. Will have a look and see if I can't jack it up a little further but they look like they are at 100% as is...
All I want is a front end I trust and right now I don't trust mine as far as I can throw it :( There must be some aspect of the front suspension setup I'm overlooking, surely the change from 225/45 to 235/45 can't be the only culprit here. Its only 4.5mm difference in the sidewall or 9mm overall.
Morning Mangs,
Too quiet in here :(
That sux dude :(.
Remember 225/45 to 235/45 is going to make the tyre WIDER and TALLER. So it could make a difference.
Yeah, it is different but who'd have thought that 10mm wider and 4.5mm higher would make so much difference. Once I get the loom sorted I'm thinking I'll go buy some 225/45 595 RS-R's for the fronts and keep the 235's as spares to replace the rears I'll no doubt ruin at the drag day ;)
Question for all. If under boost my car sounds like i am strangling a cat BUT only happens when cold what would that mean? Thinking turbo on the way out but hoping that isnt the problem.
Oh and good morning all
Looks like Joe made a call to UK customs for me! :) Thanks Brooo
18-07-2011 19:45 National Hub Received and processed
18-07-2011 17:47 International Hub Forwarded for UK processing
15-07-2011 08:38 International Hub Awaiting Customs clearance
10-07-2011 17:03 International Hub Awaiting Customs clearance
10-07-2011 17:00 International Hub Received in destination country
05-07-2011 23:58 Delivery Agent - BRISBANE - PTT Forwarded for export
05-07-2011 16:21 Delivery Agent - AUSTRALIA Collected from customer
I was told 2-4 days by Aus post, and its now been 13 and it still hasn't gotten there yet :(. 8 days to clear customs :devil::domokun:
Could be a dying turbo. Could just be a gasket or something too. worth checking out.
Customs clearance number speeds that up. average ex japan for me is 3-5 and 6-8 for the UK.
If it was gasket tho wouldnt it happen all the time and not just when cold? i am really hoping it is gasket <BR>Typical tho. First time i go to a track i get issues lol Edited by Kiwibob
I had no problem getting it here from the UK. Left the UK thursday night and I got it on Monday. I don't think Aus customs had a chance to blink it went through that fast.
Hold up has been sending it BACK to the UK for warranty (f*ck ever buying a phone overseas again). But it seems I can blame Joe for the holdup :P :
Urgh, my busted phone has been sitting in UK customs for 3 days. What's up with that?
I called them and told them to do so. Had to pull some strings but it was well worth it :nyaanyaa:
If it's a gasket it might just be on its way out at the moment so as the car heats up the gasket expands and fills the holes. When its cold it's contracted and leaves a bigger hole.
average ex japan through customs for us is about 20-25 minutes...:P
haha!!
your company is a 1000 times bigger than mine..
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
