Any mangs want some furniture? Gf is moving to nsw and is selling alot of the furniture.
hmmm. i am currently sleeping on a couch and freezing to death each night because i have no blanket. what is up for grabs?
Fridge?
Have a fridge/freezer combo. 100 bucks, works etc
Edit: full list of stuff -
Basically there's 2 matching outdoor white couches, 2 florally green 2 seater couches, one 3 seater couch would suit outdoors as it's not too appealing, chuck a sheet on she'll be right.
If you want you can come around and have a look at what you want. Alot of the stuff was all sort of bought off friends parents etc as first house sorta stuff. It's not worth a lot but I figure its better than taking perfectly good sitting devices to the tip.
Edited by hylian
Sad sad state of affairs when this is in the driveway instead of my 32
Did you do some skidz!!?
Any luck on the wheel front?
i found some 350z wheels for 500 that been painted black.
Thought I could navigate this house in the dark... nope hit a corner and now my head is bleeding. Should I stay awake or just fall asleep and hope for the best confused.gif
I did a similar thing last week, smashed my shins into the coffee table. Got a lovely cut on one leg an a heamatoma on my other leg.
Quick question Chris,
My airbag light is on and no horn. i know it is the clock spring is broken, do you/can you fix this?
If your airbag light is on, start with IGN off, turn IGN to full on (but don't start) and press the door switch FULLY in and out 20 times within 10 seconds. That should reset the Airbag codes.
If the light comes back on then you have a permanent fault. The light comes on if you play with any of the sensors at the front or steering, regardless of faults
Harden up. I would have taken the wall down
Want a tissue? Or a coffee to go with that table?
When I bought my 34 the airbag light was on. Talked the guy down in price because of the air bag fault/possible clock spring issues. As soon as I took possession of it I tried resetting the air bag codes and boom, no more fault ;)
Coffee would be lovely. Can you also get me some fresh waffles and berry's and deliver them all to my bed so I don't have to get up yet?
that looks familiar
I offered him mine to use. I have no use for them.
your bit will take me a couple of days to do. can you shoot me your phone number please.
Waiting to hear back on some stuff. Daresay it'll be on the hoist again tonight :(
Combo did one accident skid. But nothing special.
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
