I feel they are both good Col, the single player in BF3 took me a little over two days to finish (probably 5 hours playing time...)
MW3 is a continuing story and so fare has been about 7-8 hours of gameplay and still says under 50% into it!!
Multiplayer can EAD as the young idiots just bolt around committing suicide to get their points up and then sit on a hill with a rifle and do nothing...
So Zoom carwash in greenslopes for Thursday who's keen?
I would be, except my car is already clean and sitting under a car cover in the garage to keep it that way :D
I am so over games that are all about online play.
Get BF3 on a PC it's fantastic. My mate bought MW3 n I'm not that impressed.
I was fixing my pc last week, and it shat itself....
so no pc games for a while until I decide to get another desktop. The laptops wouldn't run the game to a satisfactory level.
The reason I really dislike MW3, apart from the lag, and the very badly designed environment, is that it is becoming like BF3, and it encourages camping.
I liked mw2 and black ops because it was Commando style, run in, kill as many people as quickly as you can before you are blasted yourself.
I cannot be bothered sitting somewhere waiting for people to run into the sight of my scope. If I wanted tactics I would go back to playing non alcoholic chess.
think I might call it a day shortly
Got MW3 on the day it came out, and have hardly played it.
Personally think it's a bucket of shit. Lag is attrocious, and the maps are terrible.
BF3 doesn't look much better either. Might get Skyrim or Dead Island instead...
Dead Island is cr*p, don't bother.
RE Carwash: Meh, I'll go wherever. Chermside is better :P
Mangs & Mangettes who wants to donate to my Movember fund? Donate Here Follow link and show your support. Martin donate enough and I'll see about that bikini car wash lol
Still at work until these guys clean my server room.
RE: Games - I bought BF3 the day it came out, played BF2 and had high hopes for it. After I finally got it to install I think it's pretty good, I haven't really played to much of it but I think I'm close to the end now. I think last mission I did was where the main bad dude died on the plane after you rescue him.
MW3 I'm not too phased on, it looks more of a console shooter than a PC game. I have only played the modern warfare series on 360. Call of Duty 2 though, is still hands down one of the best games I've played on PC.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
