forgive my noobism, but where abouts on the coot-tha?
There's a cafe up the top at the lookout. Easy to find.
so everyone is suiting up saturday? or at least dressing up?
Anyone who doesn't suit up is officially a skirt.
I need to find a plush toy of the dog "dug" from the movie Up! Need before Xmas, suggestions? Everything appears to be in the US.
Edit: I win at life. Found one.
Update on the 26 powered. I got stuffed around by comm bank (poor direction, poor organisational skills, etc) and it turned me sour on the deal and lost motivation. There's no gtr's for sale at the moment that really stand out to me as being a clean stock example either and if they are, the seller is asking way too much.
On top of all that my living conditions just got turned upside down so now I'm paying double the rent I was previously, which has made me want to commit to buy a house so I don't have to put up with anyone else's BS again - I'm only 21 and everyone is still acting as if it's high school.
Having said all that, I am still preparing HMAS BA for sale and planning on a 32/33 GTST to tie me over for a few years because I still miss the old skid pig we had (when it ran).
I believe I should be able to get a series 2 33 for 8k - 10k. Would you agree with that?
Edited by hylian
I'm going to be suited up, you better be too old man!
Ha! I went and pulled the only suit i Own from the wardrobe and it has shrunk about 3 sizes.
No suit for moi. :thumbsup:
Sure sure. It shrunk.
More likely you are the unti-shrink.
At the Cafe up there it's hard to miss :thumbsup:. I'll be suiting up for saturday.
cool, thanks, might come up and say gday if i have time after fixing wheels bearing for the little ladies Kraut can.
i wont be suited up so much, but def dressed up......i dont have a shirt that fits aroubd my neck with a tie without being a nuisance
You all suck! As if no suit. I'm rocking a tux ;)
Werd
I'll be rocking the tux
Werd
Turbros and dumps arrived. Winning.
Sweet as bru.
Kari Byron in a flightsuit... I am strangely aroused.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
