I'd be more impressed if it was one of the Tommy Kaira digital dashes. It still looks nice however.
as would I.
Does anyone know of a good/reliable auto electrician in the inner west [taringa/toowong] area?
I have a friend with a sus alternator on a 90's camry
Mangs TFIT
+1
Mangs what was the boost tee we were talking about the other week? Turbotech? Last thing on my list of sh*t to buy.
Mang, I have this one: http://www.ebay.com.au/itm/Turbotech-manual-turbo-boost-controller-ORIGINAL-/220798194994?pt=AU_Car_Parts_Accessories&hash=item3368991532
It is good. However, this one is apparently even better: http://www.ebay.com.au/itm/V2-Turbotech-manual-turbo-boost-controller-here-/220776081852?pt=AU_Car_Parts_Accessories&hash=item336747a9bc
Next time I need a tune for any reason I'll probably upgrade.
Hey minges.
I've had both the Turbotech and Turbotech V2. The V2 is no different in it's function. It looks different but it's noth worth the extra money. There was no difference in the way it controls boost.
Col There is a better more stealthy way of controlling boost. I'll talk you through it tonight. It's easy, Cheap (ie. Free) and very stable.
This is relevant to my interests.
We shall talk this evening. Col, does your car still run the factory boost controller?
On another note, The Stagea is exhaustimafied. Stock dump, China front pipe, Fujitsubo cat back exhaust. The Cat back is to suit an N/A so it was shorter in length than the stock one and the flange was wrong. Busted out the TIG and went to town on my new Catco highflow. Lenghtened it by 120mm.
All is well.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
