You're not wrong there.
The car is booked in for a tune at EFI on Wednesday. Need to fit Nistune, drop front shaft and up the boost a little before then.
video of the hoons being bashed
"was found guilty in Wangaratta Magistrates' Court "
For some reason i read that as Wallangarra. Wasn't any sort of weird trail fixing afterall.
Hope it all turns out well, I'll have to save like hell and hope I can get more done before too long. Mine is only set for 7.5PSI with a good 3-4 more to come as it stands but not sure if I wanna keep her as she is or go all out... Glad I dont have to worry about dropping driveshafts ect, keep us informed.
They'll set the boost when they tune it.
Not with the way my boost control works....
I didn't realise it was as bad as it was made out to be. Welcome To California...
you get off work at 12:30 on a Friday? nice deal
I haven't done much all day. Does that count?
Thanks mate. Your's turned out ok, except for the big dollars. 155kw for stock boost is good. Going all out costs too much...:wacko:
Yeah I know but it's possible plans for the future. Biggest things for me at the moment is my suspension is completely farked in the back, front not too bad but could be better so that's my main, then I got a small leak in the turbo manifold I have to reseal, the turbo drain has a small leak and VCT rewiring and new boost controller. That's what they've told me anyway.
if you are who I think - why haven't you popped up sooner..
Have been very busy the last 2 weeks with work..... Lookin forward 2 meetin some of u's over the next few weeks!!!!! Sorry i didn't go last nite i fell asleep:(
Any plans for the weekend???
Yeah I know but it's possible plans for the future. Biggest things for me at the moment is my suspension is completely farked in the back, front not too bad but could be better so that's my main, then I got a small leak in the turbo manifold I have to reseal, the turbo drain has a small leak and VCT needs rewiring and new boost controller. That's what they've told me anyway.
just a quick question.
What oil you guys and gals pour into your babies?? Ive been very happy with MOTUL turbolight....but getting increasingly annoying to find. Ralf has some penrite jazz in his.....ive never been happy with a penrite oil. :sick:
Royal purple or penrite sin, turbo light is shit, every time I have used it I have had inconsistent oil pressure after about 2000kms
ive always had nice consistent oil pressure with turbolight, Mumslayer has penrite in his car atm...and his oil pressure seems very low.
i love the idea of royal purple. but dunno if i can justify the 100 bucks a bottle :(
The Turbolight isn't a fully synthetic oil, it's a synthetic/mineral blend
If you're going to use Motul, go for the 8100 excess or Chrono V
I use Royal Purple
im not worried about fully syn and not. the cars were made and factory run on basics, so i think the 59 bucks for the turbolight will do. (which i did fine btw...locally and easily)
that sounds like an interesting oil you running there smity. hows the oil pressure? im still vary wary of penrite.
Dan [ERD] has posted this previously, and it's not the be all and end all of oil tests but it gives you a good guide:
http://www.animegame.com/cars/Oil%20Tests.pdf
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
