Another fun week begins.
To top it off, kids are teething. So bloody tired.
Miso you buy! Interestingly you can get childrens and full strength version, which is pretty good if you got a toothache
Would be interested this thurs if there's somethin goin on haven't meet any1 off here yet i'm keen.... :worship:
we usually meet up thurs nights
looks like it will be at the Kenmore maccas if everybody agrees
I washed my car today so i'm out for car washing. Up for kenmore maccas though. Have my lights working so i'll bring the skyline this time.
I'm down for Kenmore Macca's. I might be moving back to that side of town in a couple of months :) looked at a share hose in Jindalee yesterday. Nice place, big garage and two hotties to live with :)
when's the housewarming? :D
Shortly after I confirm where I'm living? Got two possibilities, the one I mentioned and another one in Moorooka. The one in Moorooka is in a MUCH better location and easier to get to work but it is 25% more than the place in Jindalee. Also, 100% less hotties at the place in Moorooka. It's a tough choice.
I think the best decision for all involved would be to put it to a SAU vote....
The other added bonus with the place that has the bigger garage and costs less to live there, is that you wont have to stand in someone elses pee on the floor.... unless they're not telling you something...
That and walking out into the lounge room and find Dush getting all flustered with the leather lounge suite
Boz, hotties, end.
Mangs, just got this email from Kingston park for a team challenge race deally on Thursday night.
Kingston Park
Team of 4 tis $80 each for 90 mins of racing. Part of a bi monthly 5 round series. Anyone keen? Need another 3 people to be interested starts tomorrow lol
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
