So who else besides NRMA and the Suncorp owned companies (AAMI, Just Car, Shannons et al.) insures grey imports? Going to vote with my feet once this is all over and NRMA will only cover my car for $12k at a cost of $1300 a year.
given that you just made an at fault claim you may find it difficult to vote with your feet Boz.
he makes a point :(
yeah shannons is suncorp owned..cant expect to much. I only have it because of the combo of Beetle and skyline was the best with the highest payouts. And from what i understand, Shannons gives loyalty discounts for staying with them.
Well just cars only worked out slightly cheaper than shannons
BUT they did increase they agreed value on the leopard (not much, but at least they were willing to discuss it), both cars are covered for everyday use (leopard was limited use with shannons policy), and no stupid restricted driver policy. They win :thumbsup:
Got the smash repair guys doing the work to give me a full, itemised copy of the quote. Only second hand parts they are using is the bonnet and AC fan & shroud. Everything else is brand new, ex-japan. the prices on some of this stuff is just obscene. Nearly $400 for the radiator fan and shroud, front bar is nearly $800 and it looks like a pair of new headlights at $1100 amongst other things. ($570 each and both are listed on the quote) Just under $4,000 in new parts for the front end.
At least the front of my car will look nice and tidy :) One plus I guess. They are also doing a full mechanical assessment over the next couple of days and will send me an itemised quote for mechanical repairs. Downside, IC and radiator are cactus. They are going to see if they can repair them and if not the new assessor I'm dealing with has said he will give PWR a call and see what they can do. Not sure what will happen with the IC as Blitz doesn't make that model any more. This new guy actually seems to give a shit, or maybe my bitching got a response.
Just got a call from Shannons :O in reply to my email yesterday.
Spoke to someone who was much more helpful, and explained to me the restricted driver condition in more detail. It's not quite as bad as I thought, but still a bit of a pain, and they still want to put it on both cars.
They were happy to increase the value of the leopard by the same amount as just car however, and said they would be happy to talk about increasing it further if they can inspect the car.
Much happier with the service this time round, they are going to send me an updated quote and we'll go from there.
Maybe I just spoke to the wrong person the other day...
That happens too, I have had vastly different experiences with them depending on who the person is.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
