Dan/Martin
Have you got any spare fittings for an rb20 block? Need the pipe that goes from the block to the waterpump as the one we have is farked.
Yeah looks like it will be going to a new home. Just have to test drive it tonight after fixing my gearbox issues.
& Pete I know of one 31 I'll be holding on to, for now anyway. However I have had an offer on it aswell.
let me know where. if all goes well I should have a bit more time over the coming months.
ask me when you see me.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
