Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Morning Mangs,
Another week...sigh. New HDD is f**ked on my computer. Won't come up in BIOS or anything. Tried all the different sata ports and power cables, tried every combo of settings in the BIOS and no dice. Finally tried it in my mates computer and it didn't so up in his either. So I've come to the conclusion that it's f**ked.
Did an oil change on the bike and got some new brake pads for the rear. Has a dead spot at around 6k and a slight miss around 10-12k. Think it needs new fuel filter, plugs and possibly the carbs cleaned.
Should have let an expert handle it ;)
Naah sounds like its borked. Take it back.
Morning Mangs,
Where did you buy it from? Places like umart and msy have horrible warranty services, best off buying a new one
It was all going so well. I was pretty happy with myself and then this shit stupid motherf**ked hard drive. Found out it needs a firmware update aswell something about write errors not being picked up or something or other. Think I'm going to change it for a Western Digital one.
Yeah people say that, but the one time I have had to return something to umart I had no issues.
You login to your account on umart online, find the order, then next to the product that is faulty there is a link to click to do an RA on it. Then you take it in to them, and they sort it out.
Downside is that sometimes you have to wait while they send it back to the manufacturer before you get a replacement, but hey, that's better than not getting a replacement at all, right? I would think that in this case being DOA they will just replace it though.
The one thing I had to take back was a video card (one half of an SLI setup). When it came time to give me a replacement, they could no longer get the same one, so they offered me a free upgrade to a newer and better one. This was no good to me though due to the SLI setup, so they were more than happy to offer me the value of the 'new' one they were going to give me to put towards a new badass video card, which I did. So basically yeah, pretty happy with their warranty service myself, although it isn't fast.
What brand did you get?
You used to be able to buy a set like this from samsung, for a couple of grand
i got a 3.5m screen now in my media room...
works better than that shit...
Everyone on my floor has disappeared. Sitting here in silence by myself. Have a feeling I'm missing out on free food.
Aw.
I had a mainboard die 2 weeks after I bought it through Umart, said it would take 4 weeks for it to come back so I just bought another. It would be better if they could just give you a replacement straight up.
Argh that sucks, I haven't had any issues with samsung drives up till now :(.
Are you sure you're not doing it wrong?
Seagate and WD is all I will touch, my boss bought 2 1tb samsung drives for a machine we were building that he needed same day, few weeks later we had to rebuild the raid as a drive had failed, a month or so later the other drive died and we just ended up putting seagates in.
I just prefer to spend the extra and get a more reliable drive, have seen DOA Seagates but the failure rate isn't as high as I have seen with Samsung. Then again, it could just be a bad batch of Samsungs we encountered.
Edited by hylian
Sup,
Back in Brisbane for a Job interview this afternoon, then back down the coast for the rest of the week. Had the HICAS light come on while on the highway. Pulled off to get some water, light off. Back on the highway and 20 minutes later light back on....grrr! Then, just to make an absolute ass of my self at the first red light I come to in Brisbane I turn the engine off to reset the HICAS light and the damn thing wouldn't start up right away! Bloody turbo timer and kill switch and alarm causing me havoc and backing up traffic on Coro Drive.
I vote me for dumb ass of the day!
I've got at least 8 samsungs spinning in my main PC, they are consumer drives (not server spec) but they run 24-7 and haven't had any issues. Also got them in my media PC, all my external drives, etc. I've been through probably at least a dozen before these ones too with no issues, and all have suffered the same abuse.
I won't touch seagate with a 20ft pole, had too many of them die on me prematurely. Maxtor were also godawful before seagate aquired them, and I do wonder if it is just the seagate drives coming out of the old maxtor factory that are bad. But there's no way to tell.
WD are my backup when samsung are not available, but I have had issues with one or two of them, but from memory when they are quite old. Hard drives are mechanical, they die after a while it is to be expected.
But yeah, im on a 100% record with Samsung so far *touch wood*.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
