Where can you get Forged RB25Det pistons Cheaply and fast!HELP!
Originally posted by Steve-SST
I have a large order due late next week but not for $900.
Steve,
Sorry should have said that the $900 was for cast ones, without rings. I am looking for a forged set as close to $900 as possible, more importantly is getting the sooner rather than cheaper because the insurance co. is paying.
Butters,
The engine was damaged in the accident as the timing belt was cut and valves bounced off the top of pistons. The dodgy insurance company wanted to just replace one piston and leave it at that. I explained to them that the other pistons must have also recieved damage and addtional stress since the engine was under load and doing several thou rpm. I am insisting they also replace the camshafts and valves since the forced of contact on the piston is transfered through to the cam lobe. I want nothing less than a proper engine rebuild and thats just what I am getting.
While I think of it whats the damage on a set of mild camshafts to suit & where do you get them from?
Originally posted by GTS-t VSPEC
$900? I doubt you'll get them for that, even at trade price, unless there made in Hong Kong;)
Nah true that.
Rocket industries flog Arias for about $1280ex , on low volume purchases (like just one set) pricing is alot keener if you setup an account or buy regularly. They come with rings and pins as well though. Have to be the best forged piston spec I've seen and they are the cheapest.
thats crap eh.
Damn insurance companies.
Friend of mine is going through simular thing. Her water pumped died. which caused the engine to over heat and kill the heads.
The waranty is only covering the water pump replacement. She has to fork $$$ for the heads to be done.
They claim the only cover the faulty part. Claim if she had stopped it straight away, no damage would have been done.
I reckon thats pretty rough.
INSURANCE companies are maggots
I fought tooth and nail with my assessor, hi manager,etc. I ended up going to the secutary of complaints.. and guess what he was a tosser as well.
So in the end you cant win.
Daniel
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
