  • Replies 91
more jackings .. Good to see that were a following the U.S trend now we have to worry about which street we drive in and weather or not we have quick track or not along with all the other day to day issues, great...! I guess in the end the one with least to loose wins. had a mate that it happened to he disabled the door from the outside (passenger) not that its much of solution but at least it will make it that much harder on an attempt.
A question i have though, if a person is involved in a carjacking where life is at risk, and you do have full insurance...would handing the keys over to avoid harm result in voiding your insurance?
i mean, technically, your handing your keys away, im sure some insurance companies will see it this way, and would be nearly as bad as the car jackers themselves.
you could also set one kind of timer in your car, something that runs seperate to everything else. something as simple as a timer that unless you hit a button once you start the car will only run for two minuttes before shutting off automatically. wouldnt be too hard to set up.
sh*t this is ridiculous. I plan on bringing my car up from adelaide to get away from all the mass-defecting-obsessed police over there, only to face theives over here! Jees, My cars just been completely "cosmetically improved" and stands out like a donkeys sack attached to a small dog.
Is it just GTRs that are the main skyline target? or GTSt's too?
"shows how badly these WRX drivers want a skyline "
"the big question is, how on earth did a WRX catch a GTR in the first place "
Thats gold, Jerry! GOLD!!!!!!!:D :D
do you think the police would fine or charge you if they found you carrying a small batton just inside the door, say if you use the excuse about "there have been alot of car jackings lately and you guys aren't always around when needed...."
how do you think that would go down?
Mr R32 M-Spec - I think it'd be confiscated and you'd be fined. Plus with that excuse you'd get done for intent to do battery, not self defence.
I think the best alternative for a battery device which is legal is a small fire extinguisher (chemical type) - you spray the bastards with the chemical and while they're temporarily "blinded" you beat the crap out of them with the canister end. Best of all it's legal because they're legal to carry (Just make sure they're in an easy spot to access.)
Just get a Maglite.
Carby cleaner works better than mace - so I have heard. .....
But I would never encourage violence or vigalantism towards armed Car Jackers. Best to to hand over the keys and let the police & tracker companies handle the rest. That way you just lose your car and not your life.
I think you have to make a judgement call based on how your car is being jacked/stolen. If it's a lone guy with some sort of hand tool threatening you through the window, then I'd say your car would be worth fighting for. But if he has a gun or if there is a bunch of them, might be better all round just to give it up. Try some stealthy tricks like already mentioned, like taking the keys out and hitting the panic alarm once you've legged it away a bit.
Of course, if you discover someone breaking into your car, a king hit and a trip to hospital (for them) is in order :P
Oh, I was thinking of it you came across them in a car park or the like. I think if I busted someone breaking into my garage, I would get them arrested and then move houses asap afterwards. One of the advantages of renting I guess.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
