Have had this problem since I got the car and it was stock as a rock and its still the same after all these mod's !!! The engine misses with any more than 12psi boost. This week all the following gear went in-
t3/t4, FMIC,PFC,Adj Fuel Reg,Big Fuel pump,z32 afm,new plugs(copper-correct gap) and we tested every coil pack with a known good item. STILL MISSING. It runs like a dream until we go over 12psi. I have been told it could be the crank angle sensor(dry solder joints??) but we ran out of dyno time and crank angle sensors. I hope I have given enough details for some of the SA GURU's to offer some idea's.
Cheers
Stevo
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/
SK - AHA!! I HOPED YOU WOULD DROP IN, IT'S GOT 7'S WITH .8MM GAP. PREVIOUS TO THESE COPPERS WE TRIED IRIDIUMS ETC AT MANY GAPS AND HEAT RANGES WITH NO LUCK.
JTECH- ITS GOT A POWER FC SO NO BOOST/FUEL CUT ISSUES
I KNOW THIS SYMPTOM HAS BEEN COVERED TO DEATH BUT I THINK MY PARTICULAR PROB COULD BE AN ODD ONE.......MMMMMMMM
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-554211
i have exactly the same problem over 12psi!!!!!!!! its very annoying so i just wind the boost down for now! and ive also done the whole experimenting with plugs, but nothing helped.
i have found that it happens alot more before full operating temp.
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-554638
Have you actually set a boost cut level. Mine is set at 1.46bar If i just touch up to it in 1st or 2nd i get a misfire if i hit it hard under full load in 4th i get complete ignition cut until the revs are back down to zero then ig comes back on and i can restart.
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-554647
Just a stab in the dark, but a mate had the same thing.
He regapped his plugs from 0.8 to 0.74 and it worked a treat - miss fire totally gone..
It's hard to believe that 0.06 mm made that much of a difference, but in his case it made the world of difference !!
Good luck.
J
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-554660
Stevo is it a series 1, 1.5 or 2? if its a series 1 have you tried another igniter module? Seems like you've replaced all the normal problem parts. This sounds electrical and it"s boost related so try another MAP sensor. Hope your'e monitoring vitals on the dyno like fuel pressure, new parts can be faulty and you need to know that all your bases are covered. Hope this helps Good luck.. :(
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-555946
Common Stevo, do the leak down test, it will rule out internal problems. Then you can confidently say its external and swap bits over. We find the best way is to get another car same model and swap them, one by one.
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-555975
Originally posted by DAMQIK GTS-T
Well I wasn't losing power that I new of but on the dyno @ 6000rpm and @ 14psi the hose sucked closed  the mixtures went really lean, (map senced ecu) those rubber hoses to the turbo are ONLY good for stock boost.
I'm not saying it's the problem but at least check it.
Lucky your car was on the dyno when it happened, you dont get too many chances with lean mixtures at load.
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-556180
Thanks boys! Leakdown down test next, then igniter module(its a series one). It has a new fuel filter and monitired fuel pressure on dyno OK. No rubber hose left on turbo inlet to crush. Probably look at the injectors next. Hey SK, when you used this fuel setup as an alternative to getting bigger injectors, could you get a nice smoooth idle? Some times (only first tune) it can be OK then it gets a bit grumpy/rough. Dripping/dirty injectors?.........will keep you updated guys.
Thanks for the input,
Stevo
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-557096
Stevo
https://www.sau.com.au/forums/topic/26146-one-for-the-gurus/#findComment-557113
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
