I have a little problem.... My mate just bought a 2000 model R8 clubsport and is convinced it is faster then my R33 so we are taking them down to Calder to see for sure. The problem is i dont want to look like a fool if he destroys me.... any one have any ideas on how it will go?
here are the specs:
R33: series 1, lowered, air filter, exhaust system (3.5"), boost up to 12psi.
R8: Stock, 250Kw, Auto
I recon he is in trouble but want to get some opinions from people who have run against similar cars.
https://www.sau.com.au/forums/topic/26162-my-r33-gts25t-v-2000-r8-clubsport/
  • Replies 56
yeah..... i know and he even tries to tell me that the holden traction control button on his dash will work like a F1 launch control box...... i really have to beat this guy, i may just wind my boost up to 20psi for the 1/4 mile run and just pray that nothing explodes.....
The tests quoted by magazines are based on a g-tech so they are very optimistic
Dont Wheels and Motor use Correvit timing, i was under the impression that this is highly accurate, only they time the cars with half a tank and a passenger so typically carrying approx 100kg additional.
As for his car being quicker... dont worry. Look at it like i do.
Not many of my friends are into cars, but typically those that are all have quicker cars... I love it, they get to spend all their money on getting their cars going quickly, and i get free entertainment joyriding in them.
He drives a Commodoor does he? Mmmmm.....
Could you ask him (and say Rezz from Japan wants to know),
HOW THE F*CK DOES HE KNOW WANT AN F1 LAUNCH CONTROL BOX IS LIKE? :looney:
Good luck, I hope you beat him:D
I am feeling a bit more confident now.... i still think it will be close, but if i lose it wont be by much and i can still give him shit for paying $35g for a car thats just faster then my $14500 car that can go around corners as well as drive in a stright line.
Yep highly accurate for a Correvit timing run Not a real dragstrip. The times are always a little too generous.
Guest Robo's
Dont get me wrong i love the skylines, but the LS1 motors are very good and make impressive power outputs. With the computers now cracked, 230rwkw is not uncommon with just tune and exhaust mods to LS1. I know they are heavy lumps, but with the added power, they can be still quick. My mate has ran 13.1 in his VX SS, 6 speed with no internal mods.
But seeing as this ones an auto, the autos slow them down alot as they LS1 loves to rev, so the stock R8 being an auto, you should hand it too him. Good luck anyway!! Its all fun.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
