  • Replies 42
If you read my post i said it is EITHER a non V-spec car OR the klm's are not correct , so if the car is a genuine V-spec it is obvious the speedo cluster is not from that car and has been replaced for a speedo cluster from a non V-spec car so the klm's are wrong i was pointing this out to any potential buyers of this car because OS30GK and yourself were so adamant it was orginal milage
please keep personal comment to yourself and YES it is a FKN V-Spec!
Hi I cant seem to send you a PM, I am in Bunbury coming to Perth end of week or so - I would like to have a look at the car, I am after a VSpec. Can you either send me an email to [email protected] or call me 0417943522 so we can catch up
thanks Mike
need this GTR gone this week moving Interstate. worst comes to worst i will take it to a car yard and see what they give me, OFFERS!
It's a 95/09 build date.
Also comes up GTR/V so that should confirm it's a V-Spec but to be on the safe side check the VINS you want "fasted" thread.
http://www.skylinesaustralia.com/forums/VI...ed-t128496.html
Thanks for posting that. I've been searching and sniffing for a early '95 v-spec build to import. I've struck out so far with june and september. THanks though, i appreciate it.
Don't do that, they will give you 15k at the most.
Better off taking it with you and holding off a little longer, you will sell it, it's just a matter of time....
Neat car with tasteful mods.
Good luck with the sale...
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
