Hey all,
Just today my car went back to being it's old self, which isn't making me happy. It has started to misfire again, or what i believe is misfiring, i am worried in case it has dropped a cylinder or something bad! When the car is idling you hear a miss in the exhaust note (like a rotary/boxer effect) and the car wobbles. when you start to accelerate the wobble kinda goes away but it sounds like it is constantly misfiring. Now this has only just came back since i got the aircon re gassed (replaced condensor with 2nd hand item) and i haven't used the aircon in the car for abit over a year.
Previously i had this issue, replaced spark plugs, coil packs with no luck, but then i replaced the ignitor module (2nd hand) and after idling for about 30secs it went to normal, and it would always misfire for a while, then after about 10 or so secs of idling it would go back to normal.
Now its gone back to a terrible idle\drive and i am at my wits end with no ideas. also the tacho needle doesn't bounce, it stays steady under idle which i thought is wierd if it is a misfire.
any ideas would be great!
Thanks in advance!
PS is it still safe to drive? it needs to be driven about 30mins in total everyday (2 x 15min trips)
https://www.sau.com.au/forums/topic/261758-need-help-misfiring/
Standard 1.1mm gap
Update: Reset ECU (held in brake and also left battery disconnected over night) started up perfect, did the daily drive and so far no probs.
Fingers Crossed!!!! :)
Edited by cabbie_bro
Update:
Started car up again about 5hrs after driving, problem came back!
I am going to buy "start 'ya bastard" tomorrow and give a spray over all the joins and vacuums lines to check for splits. might also try cleaning the AAC valve although i doubt that is the problem. I had a mate think maybe ECU??
check your plugs see if they're in a good nick and replace if necessary .. lower the gap to maybe .8 or .9mm, this is your cheapest option. Other than that, i'd take it to a skyline mechanic for diagnostic check etc
  • 4 years later...
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
