Hi guys,
was looking at the RDA rotors group buy and had a thought whether i could get R34 GTR sized discs and put them on my GTT, ie oversize the standard OEM diametre...
Not sure of the rears but the fronts are 324 vs 310mm comparatively, but the height difference is only .05mm, which doesn't sound huge but i don't know, could be a massive difference.
Would it be a stupid to run oversized rotors on standard calipers? I thought it might be a cheap upgrade because i doubt there is much difference price wise between the GTR and GTT discs.
If it is possible, would it be a huge headache to modifying whatever to make the GTR sized discs to fit?
cheers,
daniel
anyone? i'm looking to burn KRudds money on my car and this might be a place...
my logic at the moment is that the GTR rotor price is VERY similiar to the GTT RDA rotor price, so why not go bigger if it's the same money?
what i don't know is how much of a headache it will be to fit...
  • 1 month later...
no you can't. the radius is 7mm different. the only way to do it is to get a bracket to mount the caliper 7mm further out. but you can't obviously as the bolt holes will be more than 7mm. so it would have to offset the caliper to allow you to bolt the bracket to the hub and the caliper to the bracket. considering you are trying to save money, then i would give it a miss. making custom brackets to gain 14mm rotor diameter is not worth the $500 it costs you.
RDA rotors are pretty cheap troy. maybe $200 or so for a pair of slotted GTR sized ones. there is a bloke flogging them on the forum in the group buy section.
thanks for the responses guys :P
I was told i could using something called "dogbones"? that mean anything to anyone?
There wasn't much of a price difference between the GTT and GTR rotors, so that got me keen. I think it was mid $400's all up? (4 discs)
Sounds like it would be too much $$ to make the brackets. Thanks for the info :(
right o, so if i can find some already made for this sort of application then maybe it might be worth it...
where'd you get your dogbones from and were they pricey?
cheers,
daniel
yes dogbones are brackets, but for good ones your looking at $400+ for them. there is no way you'll find some off the shelf to run a 7mm diameter bigger rotor. it's just not worth it. you could get them made but you're looking at $500. and again it's such a small difference it's not worth it. if you were running 280mm or even 296mm rotors it may be worth it. but 310 to 324 is NOT worth it. if you want to waste some money on gaining 14mm in rotor then by all means dig in. :D
no thanks. Been to Race Brakes before and will never go back. Harold was a tool, the guy working on my car chipped my rim getting one of the caps off, and basically i was told to run some $600 a pair Endless Ceramic pad to fix my supposed brake issues. So much for a supposed SAU Vic sponsor :laugh:
And from a few people i've heard the opposite, the DBA's aren't much chop and to go RDA's. And considering how many people have gone through the Group Buys for the RDA rotors, surely a bunch of people would have problems by now if there were issues with them.
I think i'll probably just go with he Group Buy RDA's in GTT size, keep my QFM A1RM pads i've got now (very similar compound to the RB74's i believe, but cheaper) and perhaps call it a day. Maybe get some braided lines as well. Already got a brake stopper thingy.
thanks for all the help guys :(
best idea of the thread. :laugh:
done. Thanks for the help bubba, but ze baron is making sense and i didn't know they were that expensive.
ok, moving on. Thanks all :P
No worries, I'm with teh baron on this too - in my case it was 296mm to 324mm. I put some DS2500 pads in at the same time so I can't say how much better the bigger rotors or pads are but together, they were a hell of an upgrade over the 296mm rotors + bendix pads.
Oh and slotted 324mm rotors look better than non-slotted 296mm rotors :D
no thanks. Been to Race Brakes before and will never go back. Harold was a tool, the guy working on my car chipped my rim getting one of the caps off, and basically i was told to run some $600 a pair Endless Ceramic pad to fix my supposed brake issues. So much for a supposed SAU Vic sponsor :starwars:
thanks for all the help guys :blush:
interesting...
i still havent cracked my RDA fronts, and i rate RB74's over endless SSS(FWIW)
    • Hey Murray, hope all is good. I took your advice and put the filler first then the putty. Seems like a much better result but i noticed there are still pinholes. I even had pin holes when i initially put the putty on the body filler. Do you think it has something to do with my spreader being f*cked? I attached some images. This is the intially body filler i sanded. No putty yet  Applying putty. Final result after using wax and grease remover can see the pin holes. I just noticed as i look at the putty application it looks wavy not sure if it's supposed to be like that or because of the spreader.
    • Hey all just wanting some advice. I’ve just compression tested my RB25det and these are the following results  Cyl 1 - 135psi Cyl 2 - 135psi Cyl 3 - 120psi Cyl 4 - 140psi Cyl 5 - 130psi Cyl 6 - 125psi   do these numbers seem ok.  Thanks in advance
    • I must say - this is how I picture all R31s!
    • Rust repairs completed, doors back on! pretty much totally back together running now. All future repairs will be fiddly wiring getting everything back up to road condition.  hasn’t  taken that long considering the condition I got the sub. note my helpers keeping the back seat warm 😂
    • SAU NSW Old Pac Cruise to Newcastle All Japan Day 2025 Sunday 27th July 2025 5:00AM Meeting Berowra Station Commuter Car Park 2 5:15AM Departure Cruise Via Old Pacific Hwy 7:45AM Arrival to Lambton Pool (Regroup) 8:00AM Arrival to Newcastle All Japan Day 2025 Meet Location: Berowra Station Commuter Car Park 2 Stop 1: Lambton Pool (Carpark) Final Destination: McDonald Jones Stadium for Newcastle All Japan Day 2025 Tickets: Newcastle All Japan Day 2025 $20 Per Car Spectators Free PURCHASE TICKETS HERE *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
