You could make them fit by buying a lower sized wheel? Lol 20" is just TOO big in my opinion. Good luck fitting, I got no other suggestions.
NAwww they are sexy tho :down: haha. anyone else got suggestions?? what if i flared the guards and got spacers??
if its hitting on the side the offset isnt right and you can fix it with spacers (make sure you get longer studs put in if you go this way), but then it will probably sit out the guards too much and you wont be able to lower it.
if its hitting at the top the tyre profile is obviously too high, 245/35 is huge for the front, shoudl be fine on the back, 225/30 is the way to go on the front and if the offsets are right you should be able to deck it hard.
The steering arm is sitting 1/4 over the tyre already... they are gunna be sitting way outside my guards.. lol. Im not lowering it. so not sure... :down:
iv got 20's on mine with 225/35's on the front and lowered, if you can stretch a tire it will be alright, as for top of the strut elbow joint the clearance wouldnt be any more than a 3mm gap, but doesnt cause any problems. just make sure if its lowered the suspension is tight otherwise when the wheels are turned under hard cornering or similair the tire will hit... flaring or wide body fenders will fix the problem but as said above it is a bit of stuffing around.
your username and presumably rego is 4drftn and you have 20's?
DAMN you must have a lot of coin! :laugh:
lol, yeah i had a set of deep dish 17" volks when i first bought the car, chucked the 20's on to raise it off the ground so i could get out off the driveway... would like a set of nice dished racing rims though...
no offense, but thats about the most stupid thing ive heard all day.
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
