hey man im after a set of bosch 6000k h3c to fit my cefiro could you please pm me some payment details?
PM sent.
i have a r32gtr with those projector lamps. was just wonderin what bulbs would fit?
Not sure mate, pull one out and have a look.
Get back to me.
  • Replies 115
3 questions. Has any1 fitted these to their high beam as im goin to be doin alot of country driving and want brighter high beams.
Do they make a kit in the phillips that would replace my high beam which has H1R1 or would a normal H1 fit.
Can i get a price on a h1 kit in then phillips in 6000k and the other kit that would suit my car in either 8000k or 10000k
Thanks
Thanks
1. Yes, there are kits for high beams.
2. Never heard of H1R1, might be just H1.
3. $225 for H1 PHILIPS 6000k delivered, i do not recommend anything over 6000k for highbeam as the LUMEN rating is lower as you go higher in KELVIN rating.
Meaning the the higher the KELVIN rating, the brightness starts to drop.
EG: 6000k= 3100 LUMEN
8000k= 2900 LUMEN (this is still approx 3 times brighter than halogens)
Hey thanks for that ill have a look at the light 2morrow and see if a normal h1 will go in there or if its sumthing else. Ill take a photo of the bulb aswell and post it up for you as i think the r34 use these bulbs in their high beams.
done a bit of research and found out that a normal hb3 will fit in my car instead of the HIR1 (misspelt it before). Can i get a price on 3 kits all delivered 2gether. Im after a H1 kit in 6000k, D2R for my lowbeam in 8000k and hb3(9005?) for my high beam in 6000k delivered to Bathurst 2795 Thanks. Ps this is a photo of the bulb that is in my car.
Last batch sent.
There is also a Vega Diamond 4300k H1 kit ready for immediate shipment.
OEM colour with 3x the brightness of halogens.
$160 Delivered.
Suits all R33 GTSTs
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
