DETAILED SEVERE THUNDERSTORM WARNING
for LARGE HAILSTONES and FLASH FLOODING
For people in parts of the
Sydney Metropolitan and
Blue Mountains/Hawkesbury areas.
Issued at 7:03 pm Wednesday, 25 March 2009.
The Bureau of Meteorology warns that, at 7:00 pm, severe thunderstorms were detected on weather radar near Richmond, Wilberforce, Bringelly and Mulgoa.
These thunderstorms are moving towards the northeast to southeast.
They are forecast to affect Badgerys Creek, Leppington and Oran Park by 7:30 pm and Campbelltown, Hoxton Park, Macquarie Fields, Maroota, Minto and Wisemans Ferry by 8:00 pm.
Large hailstones, very heavy rainfall and flash flooding are likely.
The State Emergency Service advises that people should:
* Move your car under cover.
* Keep clear of creeks and storm drains.
* Don't walk, ride your bike or drive through flood water.
* Unplug computers and appliances.
* Avoid using the phone during the storm.
* Stay indoors away from windows, and keep children and pets indoors as well.
* For emergency help in floods and storms, ring the SES (NSW and ACT) on 132 500.
The next warning is due to be issued by 8:05 pm.
https://www.sau.com.au/forums/topic/262660-hail-warning/
FAIL, LOL
CANCELLATION DETAILED SEVERE THUNDERSTORM WARNING
Issued at 7:46 pm Wednesday, 25 March 2009.
While thunderstorms are continuing in parts of the Sydney region, the immediate threat of severe thunderstorms has passed. The situation will continue to be monitored and further warnings will be issued if necessary.
https://www.sau.com.au/forums/topic/262660-hail-warning/#findComment-4498458
  • 5 months later...
Made it home with 2mins to spare before hail came down on Sunday for a couple of minutes. Im paranoid these days as our BA falcon got dented up real bad in that big storm back in Dec '07. That was the one that wiped out all those house roofs across Blacktown, Seven Hills etc. Took 9 months to get into a panel shop!
https://www.sau.com.au/forums/topic/262660-hail-warning/#findComment-4840552
Can someone update me if there is hail?
I need to drive the bluebird there...and the mrs needs to drive her 323 there too :D :D :D
Want to drive the my boat there too? I figure I'll turn my car into a pure track pig if it gets written off by hail :)
https://www.sau.com.au/forums/topic/262660-hail-warning/#findComment-4841029
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
