I would like to put on a Nismo Z-tune style GT-R bonnet on a GT-T.
Already getting the East Bear front, but don't like the look of their bonnet.
What would I need to do this?
Hinges, locking mechanism, front wings?
im sure there are several threads covering what you would need to fit a gtr bonnet to a gtt, do a search, and you should get a more definitive answer.
im pretty sure that its just the hinges, mechanisms to keep the bonnet down/bonnet release, and the obvious gtr styled front bar or gtt bar with a top mole.
Yes Rush is right, there are a few threads covering this.
Here is the part numbers you will need to order from Nissan Japan ( order via Local Nissan Dealer and they will import) You will also need to pay for the parts up front before your dealer will order them most of the time.
I will also list the prices but dont quote me ,the price may have increased slightly since i purchased mine.
Nissan GTR OEM Part numbers
65400-AA400 - Hinge Assembly - RH - $81 Australian
65401-AA400 - Hinge Assembly - LH - $84 Australian
62550-AA400 - Stay - Hood Lock - $88 Australian
65601-AA400 - Male Assembly Hood Lock - $100 Australian
It will probably be easier to use a GTT front bar with a Nose attachment rather than going all out to modify a GTR bonnet ( i went all out, very expensive and long time - need much patience) If you choose to go a GTR bar and not modify it then you will need to change the guards which will also mean bigger rims to fill the space or spacers which i wouldn't recommend.
All the best with this.
David.
Sorry for not using the search function (usually the first to tell others they have to :P strange :P )
I'm going for the East Bear Spec 2 kit from Knight-Racer, but as stated I want a different bonnet.
The GTR bar from KR will fit the GTT wings.
NZMO thank you for the part numbers.
Is the locking mechanism easy to change or do you have to drill holes in the framework to fit the GTR lock?
And the GTR bonnet is just as width and has the same front line (where the headlights are mounted) as the GTT bonnet?
Edited by mgb2002
As far as i know that bonnet is exactly like the gtr, meaning the front of the bonnet doesnt fold down like the gtt. So it would be exactly like putting the east bear bonnet on, but...ztune lol.
If thats what your talking about.
Edited by Darkplague
Josh's ( JSAI ) their Z-Tune Bonnets for the GTT actually do fold down over the nose.
hey NZMO, are they impul side skirts?
yes they sure are, im not sure what ill be doing in the coming months with them as im going for GTR rear guards(which means ill also have to change my rear bar to a GTR bar to line up - hence my signature wanted to buy ) and Z-Tune front guards being GTR fitment i dont think ill be able to keep these skirts as ill have to go either Z-tune skirts and modify them not sure as yet.
Sorry for not using the search function (usually the first to tell others they have to :down: strange :P )
For the locking mechanism there is not to much involved and as for the bonnet it does line up with the guards line and head lights.
Good luck with your project, i know its not going to be cheap.
Nice kit too , my front Bar is Top Secret GTR.
cheers,
David.
Ah ok my bad the jsai gtr and gtt ztune bonnets looked identical.
hey guys ...
sorry if this is out of topic, i was wondering where can i get a east bear front bumper spoiler/lip for my gtt in melbourne?? just really hard to find the lip...pls help!! PM me if anyone can help..!
  • 3 weeks later...
hey guys ...
i want to know too... :)
and can someone tell me how does GT-R front bar not fit to GT-T(if i already fit a GT-R bonnet, Hinge Assembly & Hood Lock )?
is that the front guards too big or what??
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
