Selling all my stuff decided to go a 26 in the car instead.
So Here we go.
Turbosmart Pro Gate 45mm $600
GT3540 Never used, 0.82 Rear comes with oil and coolant lines. $1700
6boost Manifold to suit 25 external wastegate, has V-band flange welded on. $800
550cc x 6 injectors one injector sticks open thou. $400
Adaptronic ECU with 3bar Map sensor $700
RB25det Neo motor with greddy copy intake and 80mm throttle body, with 750cc R33 injectors and rail.
motor has done 76k, Has only ever ran stock boost.
No turbo or manifold. $2000
All parts are open to offers
Parts are located in Perth, Thornlie
https://www.sau.com.au/forums/topic/262925-rb25det-engine-and-am-parts/
manifold, turbo, gate, 750cc injectors and rail, and intake plenum is sold pending payment.
RB25det Neo motor no turbo, manifold or injectors or intake plenum
$1200ono
sorry it went today.
Only got
$1100ono
motor has done 76k, Has only ever ran stock boost. i do have stock plenum but missing couple things, and throttle body.
$1100ono
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
