I am running one in my silvia, there pretty good quality for the price and much larger than standard. Mine bolted up perfect, just as good as a stock one, retains factory shroud and hoses as well which makes it simple. Took about 15 minutes to swap it in
Only thing I had to do was trim down the top radiator house about 1cm as the radiator is much thicker and sits closer to the engine
My friend just bought one for this R32 last week and it dropped straight in, no problems at all
Few drifters on NS.com using them, haven't heard anythig bad about them
Picture below so you can see the quality, I scored mine for $199 pick up so if your in Melb go and grab it and save on the $50 courier cost
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4511148
great, thanks for that abu,
i didn't realise there the option of pick-up, i was going to buy off ebay and it stated 'online sales only' but i am in melbourne so i will definately be doing that. do you remember where you picked yours up from abu?
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4511349
Yeah they don't advertise pick up on the EBAY ad but when I messaged them and requested for it they were happy for me to collect it. My friend also picked it up a few weeks back, there located in Mt Waverley
Try give them a call on 0433 657 560
Thanks
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4511426
Yeh im using a ASI in my gtr its pretty good, i sorta regret it but because its the only china product i have on my car and it say's ASI over the the fin's where now i wish i said GREDDY or something lol. and it has ASI printed on the top of the radiator near the cap haha. But they do the job so i guess i wont be replacing it unless i have to it only cost $250.
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4512202
Hi guys, I actually make radiators for a living (aluminium)
It's a simple technology, air passing over the fins, water passing through the tubes.
Chinese radiators dont look as good as hand made radiators by quality fabricators, but they do work.
Materials may not be as good, tank folding or tank welding may not be up to scratch and general fitment problems... You do pay for what you get.
I'm running a chinese radiator core with my own hand folded and welded tanks.. works good.
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4514419
you earth them to avoid electrolisis which eats away at the alloy and can end up causing them to leak from all over the place usually ends up being 100's of pin hole leaks in the solder joints of the tubes to the header plates.
with alloy radiators it is reccomended that you run a glycol(sp) based coolant, i usually use the 50% tectaloy shit.. no water just 2 5 litre bottles is enough to fill the system and the overflow
but yeah... thats just me
doesnt hurt to throw in a bottle of redline waterwetter either more so for the engine side of things to help avoid airlocks in the system.
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4515413
^^damn that's no good, i'm picking mine up tomorrow so i'll be sure to take my tape measure along too.
was also going to ask, are specific coolants needed for alloy radiators? or will any quality coolant do the job? Cheers!
You can use any coolant just don't mix and match brands/types etc as I read recently that if you mix different types of coolant it can cause corrosion
Have a read of this thread, it's pretty informative also goes through the procedure to check for electrolysis and a heap of other stuff: http://www.nissansilvia.com/forums/index.p...=denso+radiator
Definitely fits R32 GTST, seen it my self so no need to worry :P
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4515480
spose this is one thing i missed, the main reason you dont mix coolants is due to its possible for there to be a chemical reaction and it can actually turn into a thick paste that blocks everything and well yeah.. is not good
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4517167
arrived today, welds look dodgy and it has been sprayed with like spray on chrome or some shit?
i can clean alluminium radiators with mineral turps on the outside to get this paint off yeah? wanna see if it has big scratches or something and they are trying to hide it.
https://www.sau.com.au/forums/topic/263619-asi-radiator/#findComment-4532928
    • Found the answer: it wont fit without a bit of work- you'd have to change the guards as well
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
