Side skirts sold
AFM sold
i would have the hand brake assembly but like what exactly do u need in detail like the hand brake its self the hole thing blah blah list them for me please pm me
Abu explain to me how to figure out if my cage is 4pt or 5pt lol then i can tell you thanks :)
  • Replies 40
All parts are anogotiable
pics will be up soon and any part u need ask me and i check if i got them, i live in melb so pick up will be preferable and take the parts off ur self, if posted interstate give me area code and i get price but its at ur own expense, Any quiestions just ask
List of parts i got.
R32 GTR RIMS $500
Has scratches on them with rears got enough tred and fronts need new tred
Front and Rear Rotos: $200
these are basscily brand new i only on car for 6 month still brand new. brand are RDA sloted disk rotors i bought from group buy.
Front and rear calipers $300
these worked fine with me still in good condition
Dash $ 85
no includeing the passenger side airvent broken and mid airvent sold
Intrument cluster $100
perfectly fine with low Ks on them
Engine $900 this one is pick up only and take it out your self
engine is still working come check it out ur self
Wheel hubs $340
GTST bootlid $120
in good nick is a black with cherry pearl color car been resprayed that color
GTR bootlid with gtr Spoiler $220
boot lid has some damage but not major u see when i get photos and spoiler has some damage
GTST fron Quarters $300
these i took off car and put away so they are in good conditon same color and boot lid price is for both
passinger raceing seat $180
in good condition auteknika is the brand black and grey color
driver stock seat $150
in decent condtion i get pics
Rear seats $200
good condition
GTST Mspec side skirts $200
in good conditon chery black colour
Gear box $800
good condition
Brake master $200
i had this reconditon only drove on it for 6 month recoed
Mushroom Pod HKS $70
AFM $70
Strut brace R32 GTST $120
Rear Bar $120
we can discuss the prices, and ask me anyquiestion and any parts u need and i check if i have it
$200 posted for the side skirts ?? to wollongong??
R32 GTR RIMS $500
Dash $ 85
Wheel hubs $340
GTST bootlid $120
Rear seats $200
good condition
Gear box $800
good condition
Brake master $200
AFM $70
Rear Bar $120
hey bud, still got the motor?
where abouts are you located?
pm me best price you want for it if still available
cheers
sorry side skirts sold
yes i got sun visor.
Pm for motor sent.
i dont know what a g sensor is tell me about it and i have a look but since i have't herd of that i still got it on the car but i have a look if u can tell me where to look
Disk Rotors are sold
I got the drive shafts do u want to come and check it out, your more then welcome they on the car still. and i get u a price just pm me if u want to come by
Pm sent Plate
Hey dude. with the handbrake. id be after the actual lever and inside parts. spring, button, Not the leather cover or plastic case.. But im in geelong and could pick up if you give me a price thats ok. Also might grab the rotors as well. as long as they will pass RWC, mine are under size.
cheers mate.
Lule
Pm sent Plate
Sweet. How many k's have they done? What sort of power did the car make?
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
