vct affects your midrange torque and power more than peak (high rpm) power. not 100% sure on the rb series, but on the vg and vh engines it is only on until around 5000-6000rpm, then it switches off.
from what i understand, the idea is to increase valve overlap at low/medium rpm (not at idle though) to help suck in the in intake air/fuel mix and blow out the remaining exhaust gases. however at high rpm the pressure in the exhaust manifold may be high enough that some of the exhaust gas will actually be pushed back into the intake due to the bottleneck in the exhaust manifold... this would cause a decrease in power and increases your cylinder temps. so to avoid this they switch off vct at higher rpm's.
basically with vct disabled, there will be very little (if any) difference in your peak power compared to if you had working vct. your torque curve however will drop away after the peak torque, whereas with vct it will be abit flatter towards high rpm and your midrange power would be reduced.
i know the RB30 guys had a couple of dyno graphs in the forced induction thread with and without VCT. not a 100% sure exactly, but the difference was something like 10-15kw over a 1000-2000rpm range.
i don't know how applicable that would be over to an NA RB25, but i would say probably about the same taking compression into consideration????
my vct isnt working because I'm running a r32 loom and ecu.
I know the peak power is the same as vct is turned off in the higher rev range. was just wondering if anyone had some dyno plots so i could see the midrange difference.
why are you running a 32 loom and ecu? did u do a engine swap?
when did the vct's start getting used? what model onwards with the skylines?im not trying to hack the thread but my 33 is extremly gutless low and mid nothing starts happening until 5500 rpm?
its a s1 1993 r33 btw
Edited by LUME
VCT got bought in with the S1 R33s and from thereonwards was standard. easy way to tell whether or not it has VCT is whether it has a buldge on the lefthand side of your timing belt cover.
the only RB25DEs without VCT were the ones from the R32s, VL owners usually use them on RB30DE builds as they dont have to modify the block as much.
Luke, i had the same problem that your having. just launch it at about 4-5k RPM and you should be alright if youv got grippy tires, cos thats where the torque band is. i gained heaps of bottom end go when i turboed mine, cos of the high-comp motor.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
