  • Replies 41
hey guys n girls ive wrecked one of my 32s, ive still got heaps of shit left over
engine cross member $100
front lower control arms $ 100
upper arms new nolothane bushes $ 50
mint vicous lsd $150
Mint manual tailshaft $100
axels $70 for the pair
5 stud hubs $100
mint boot lid, white, no spoiler $ 70
passanger and drivers doors with petty much everything $100 each
dash cluster 180 xxx $ 80
interior eg front rear seats $150
extreme 6 puk clutch, still fine.. about 50-60% meat on it.. $150
r33 rb25de head $450 has new exhaust studs
type m stockl front and rear bumper ok condition $100 bucks for both
custom castor rods with new nolothane bushes $70
stocko suspension $ 150
front coilovers.. unknown brand no leaks $100 bucks
ive got heaps of random stuff laying around so if you need something drop me a pm or msg me on 0433 690 019
im in morphett vale, adelaide
cheers, Nathan
wanting interior trim near rear window on both sides for r32 gts-t not broken
everything still here.. Now have a white bonnet, white rear bar, purple rear bar, stock dump pipe and front pipe.. Everything has to go!
hey just wonderin if u got the wirein harness that goes from the ignitor box to the computer and injectors? i just need that wirein harness
na sorry buddy i dont..
hey mate u get my first post u should feel lucky i need left blinker radtatior and mushroom filter if u got one and a low klm cluster
ive got a cluster with 180 on it..
im after the hubs...will they suit a s13 stud conversion?
if so ill have them
im pretty sure the the rear ones will.. dont think the front ones will.. do a bit of a search and get back to me.. ill give u the handbrake assembly for free if u buy the hubs
got any pictures on the front&rear bar?
looking for r32 gtr front bar with lip!!
i have one which im willing to sell some time soon, how much do they roughly go these days?
Edited by silbastian
heyy,
im looking for a 92 GTST passanger side front guard and passanger and middle air vents in good condition. any chances?
Thanks heaps :(
na sorry buddy, some gaurds but they have dents n shit..
  • 4 weeks later...
Hi, was the car ABS-equipped? I am after non-abs brake lines that are connected to the master cylinder - there are three of them; I am after the one that goes to the rear of the car (it's pretty shirt) and the one that goes to the driver's side tyre well.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
