Hi all
I have a 34 making 230 odd rwkw and it has started to tramp real bad in 1st and sometimes in second.
It has potenza for the street shocks iv never herd of them and imagine their from japan fitted before it was imported.
Whats an easy way to fix this problem. can i just get new shocks for my car?
https://www.sau.com.au/forums/topic/264275-r34-gtt-axel-tramp/
I'd have to agree. Pineapples in the squat position are the best thing to do. I have also added Unique Autosport diff bushes and have eliminated it all together. Has nothing to do with springs and shocks. I chased that crappy idea for a year before deciding to start at the diff and go from there. Lucky for me that made a huge difference and the pineapples fixed the rest.
Dunno if there is a fulcrum suspension down south. but i just received a quote from them today and part of it was Rear diff pinion mount kit - $61.78c
Dan at elite racing does the whiteline pineapples for about $90ish i think. can also be had from ebay
Damn, i was just about to post the same thread...Glad i looked...
Mine was tramping a bit before, but not with 250Rwkw its hopeless, its progressively getting worse i think!
With the pinapples that people are recommending, are these the alloy type ones i've seen advertised (Skylinecouple??)
What diff bushes are you guys referring too?
Silverr34gtt - Can you please PM me with the result and cost? Be much appreciated :P
I have the yellow urethane ones but I have often wanted to try the alloy. From my way of thinking the pinapples are designed to change the pinion angle mostly to help the rear end squat or lose traction for your particular motorsport. The alloy ones are for locking the subframe and stop lateral or front to rear movement when cornering, stopping or accellerating. I had an idea where I could put the required pinapples in to help the car squat and the alloy ones on the other two locating points to stop lateral movement. Take my advice with the diff bushes, I have said this before, NO axle tramp.
Diff bushes are from Unique autosport and pinapples anywhere really. The sponsors here on the forums are the best place to start.
skylinecoupe are those diff bushes ur talking about the red ones that go on the 4 mounting positions?
i already have those Bee R pineapples set to traction i still have really bad axle tramp think i might give these diff bushes a try are they hard to put in? im not keen on taking the diff out again i just did that i blew my diff to pieces lol... i get the feeling it was because of axle tramp and maybe because i angled the diff with those pine apples..? if i put these diff bushes in i reckon ill change how i have the pine apples set up and just putt all four on the bottom and see how that goes..
Yes the red ones. They merely replace the originals but are much stiffer and if you already have had diff replacement then you have been flogging the bushes every time you dropped the clutch or accelerate then decelerate. Be carefull because some mechanics are good at convincing you to only put the front ones in but only because they are too lazy to take diff out. Besides, you can do it yourself. Even if you just do the front ones I'll bet there is a difference.
10% of the time it’s tyre pressures, the sidewall flexes and releases. Try pumping the tyres up and see if the axle tramp stops and/or gets less.
5% of the time it’s worn subframe bushes, since you have fitted a rear subframe alignment kit (pineapples) I suspect that isn’t the problem in your case.
25% of the time its drive shaft angle, the car is TOO LOW and the angle of the universal joints are winding up the drive shafts. If your car is lower than 345 mm centre of wheel to guard on the rear, then try raising it up.
60% of the time it’s incorrectly matched spring and shock damper rates. The rebound (extension) damping is not sufficient to control the oscillations of the springs. Standard springs with worn shocks get this problem. BRAND NEW aftermarket coil overs get this problem where the spring rate is too high for the shocks to control.
Once you have eliminated 1, 2 and 3, then your problem is #4
:stupid: cheers :D
This is exactly the type of nonsense I'm talking about. Start with a solid diff that has had the bushes flogged out of it over 10 or even 15 years and work your way out. Stop following the same old advice. Sydney kid is right of course but only if you have the diff tied down tight in the first place. Did the Skylines have bad axel tramp when they let the factory ? No, they didn't. So if a brand new car with soft suspension didn't why would the same car with more pwer to spin the wheels and better (stiffer) suspension have teeth rattling tramp now !
D-Project Alloy Subframe Bushes :
$135 Delivered to your door (no pickup).
Easy to install yourself if you know your way around cars.
Pineapples and Squat/Antisquat work in the short term, but they will not fix or secure the shagged subframe bushes. You can still setup the subframe for squat/anti squat with the alloy bushes, but we have found that all 8 installed is the best setup.
We also have replacement subframe bushes OEM style for $199 Delivered
Diff Bushes etc are in development.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
