Hi, just selling a range of parts to suit an R32 GTR, these parts were on the car which made 240awkw with this set up.
I have 2 x T25 turbos (I think)
specs of the turbos are,
M24 Garrett, 0.53 inlet and 0.48 on the exhaust side
The number on the id plate of the turbos read T702987-3
Turbos have done about 30,000k one has slight shaft movement and the other has virtually none. Both spin freely and were in perect working order when removed from car, only changed due to upgrade. I was told that these turbos are the standard item fitted to the R34GTR's. I can tell you that 240kwatw is about all you will get out of these turbos, they have vertually no lag and are very strong through the midrange, but they do run out of steem up top. By about 6000rpm in third gear I noticed the power flatten out. Car ran mid 12s with these turbos. They are a good upgrade from the standard 32/33 gtr turbos as they are steel wheel, not ceramic so they wont break.
After $400ono
Also have standard R32 GTR intercooler $250ono
Turbosmart 2 stage boost controller $80ono
Standard R32 GTR injectors and fuel pressure regulator. Make an offer?
Injectors need service.
8 x standard GTR coil packs. Make an offer?
The two extra came with the car when I bought it, the origional 6, at least one is faulty, car had a miss with these fitted, dont know if there is a way you can check to see which ones are good.
R32 GTR Mines tuned ECU $200ono
EMS ECU with wireing harness, this was piggybacked to the origional ECU in my car. This is an old model EMS but might be useful to someone,
$250ono
Origional GTR intercooler pipeing as shown in pics, $40
Apexi pod filters attached to standard air flow metres. $100
Air flow metres appear in good nick dont know how to check them and they were never functional in my car as it always ran map sensors in the time I have owned it.
Cusco front strut brace, $60
Blitz to atmosphere BOV with custom made (looks abit dodgy but works) 2in adaptor. $80ono.
Items are located at Minchinbury, in Sydneys west, Im a stones throw from WSID. Im happy to post the smaller items at the buyer expense, the larger ones might be too expensive but Im happy to try and get a price for you.
Any questions or if you are interested in anything, just give me a call,
Moray, ph: 0414 355 383
https://www.sau.com.au/forums/topic/264330-r32-gtr-parts/
Injectors need service..
What are you thinking for these?
Ones in good nick go for $200ish or....
https://www.sau.com.au/forums/topic/264330-r32-gtr-parts/#findComment-4520898
hi, pretty interest in boost controller
is that a Dual stage one? how about the condition, and workin order? any faulty
cheers
Boost controller was in full working order when removed from car, has since been kept wrapped and protected. SO should be in full working order, these are pretty basic items, cant imagine having any problems with them, also comes with red boost switch. The switch changes from 1st setting to second setting, so yes it is a duel stage item.
Thanks.
https://www.sau.com.au/forums/topic/264330-r32-gtr-parts/#findComment-4521445
  • 3 weeks later...
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
