Hi all,
If I am getting a new Exedy standard replacement clutch kit (NSK-7172) for an R34 GT-R put in and I am getting the flywheel machined, do I need to get new flywheel bolts as well? I was always under the assumption that you only need to get new flywheel bolts if you get a new flywheel?
Any info would be greatly appreciated.
Cheers,
https://www.sau.com.au/forums/topic/264377-new-flywheel-bolts/
Which bolts are you talking about? Flywheel to crank or pressure plate to flywheel?
The flywheel to crank bolts are pretty chunky, so there's less chance that some retard has damaged them by torquing them up too much. The pressure plate to flywheel bolts on the other hand.....
Also,
- make sure that the dowels are in place before you re-fit the pressure plate
- use engine oil on the threads of the flywheel to crank bolts (the torque spec assumes you have done this)
- new or machined flywheel is not going to make any difference about re-using the bolts AFAIK
- you should really check the workshop manual to see if the bolts are re-useable... i re-used mine because i didnt even think about whether they should be replaced or not
Yeah im refering to the flywheel to crank bolts. Pretty much all aftermarket clutches (that come with new flywheels) come with new flywheel bolts dont they? This is why I am now interested to know if I will need them too, even if the flywheel gets machined.
Cheers,
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
