I have an O2 Sensor from a RB30, and there are 3 wires... here is the problem :
What are the wires for?
1x Yellow Wire
1x Black Wire
1x Red Wire
Black and red and not power wires are they... this is standard + / - stuff, but I wouldn't think that the sensor would require external power?
Is the Yellow wire the signal wire, and the other 2 heater wires?
What is the Yellow Wire for... any help would be V. handy !
Thanks guys... I await speedy reply's
https://www.sau.com.au/forums/topic/26467-o2-sensor-help/
1) Get a multi meter
2) When you cross 2 of the wires you should get a reading of 10ohm or less... these are the heater wires
3) When you cross the 3rd wire with anything else... it should read 'open circuit'... this 3rd wire is the signal / sensor wire !
just F.Y.I ... Thanks Bozz !
https://www.sau.com.au/forums/topic/26467-o2-sensor-help/#findComment-560007
red is power for the internal heater
black is ground (other end of heater)
yellow is interesting. aftermarket? the ones i've seen are white but would be the actual probe which returns 0-1v depending how much exhaust gas is passing past.
note that O2 sensors are matched to different ECUs and the stoich curves may be different (ie an RB30 O2 may have a more narrow curve than the RB25 ECU is programmed for)
https://www.sau.com.au/forums/topic/26467-o2-sensor-help/#findComment-560405
I have the ca18det and the plug goes. black white red (left to right) on the other side of the plug the black goes to a blue, white to grey and the red goes to a grey with a white trace.
So what im trying to figure out is which one is the signal. the instructions say that its not polairty dependant for the heater wires. the replacement has 2 black and 1 blue. (universal 3 wire)
https://www.sau.com.au/forums/topic/26467-o2-sensor-help/#findComment-560492
If you want to know the difference between the different types of O2 sensors, try this link: (about half way down the page)
http://www.ngkspark.com.au/tech_info_oxyge...nsors_index.htm
Also, the current NGK Spark plug & O2 sensor catalogue has detailed information on these including pics of the different plugs - great for matching up an alternative to that expensive OE Nissan sensor!
https://www.sau.com.au/forums/topic/26467-o2-sensor-help/#findComment-560617
Should'a just called me to begin with :rofl:
BTW can I borrow your car for a few hours one of these days, need to swap bits to find a fault...
https://www.sau.com.au/forums/topic/26467-o2-sensor-help/#findComment-569116
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
