Hi, came across this while I was “working” and thought there would be a few people here that would appreciate this game, you know who you are! :)
"Sammy Studios, Inc., a developer, publisher and global distributor of interactive entertainment content, today announced Drift Racer: Kaido Battle, a new videogame simulator based on the exciting sport of drift racing coming exclusively to Sony PlayStation®2 in February 2004."
The game offers five modes of play for stylistic precision-driving, racing for 1 or 2 players and a career mode that pits players against nearly 200 underground racers in official daytime events and underground nighttime races. Drift Racer: Kaido Battle is tricked out with features, including environment effects for all four seasons, weather effects such as rain, snow and fog, replay movie galleries and licensed in-game music from known DJs
Yeah baby......
https://www.sau.com.au/forums/topic/26478-drift-racer-kaido-battle/
theres also the initial d PS2 game due soon.... its a great time for us import drivers indeed!! :)
i thnk thats the game i have this movie of a 350z from.... looking at the pics... definately is ;)
Hey Adzmax!!
I think your source of information is wrong. Kaido Battle is a game produced by Genki in Japan, I already have that game on PS2, i have had if since April. Its been out ages ago in Japan. And also with the Initial D games as well, it has been out a few months ago because i already have it. If you any of you are interested in buying the game, i can get the guys number and you can give him a call to buy the game.
BTW, Funky Monkey, i got my PS2 mod by this guy and he is pretty good!! It cost me about $140. This guy sells all the latest games from Japan and US, everywhere. The only problem is some of the games are in Japanese, and you have to remember which menu to select.
There is also another game that rocks. Its called Shutokou Battle, or otherwise known as Tokyo Extreme Racer (TXR) in Australia, however it is not very popular here, but i think it is betta than GT3. Australia only has TXR Zero at the moment, but Japan released Shutokou Battle 01 a few months ago which i have myself, and it is really good. Its based on street racing in Japan, and all the roads in the game is exactly what it is like in Japan. You can mod pretty much anything on the car, bodykits (veilside, do luck, etc), wheels (works, etc), colour of your lights...blah...blah..blah...you get the jist!!
Sorry for writing so much!!!! But i hope the info was helpful
BTW i am new to this forum, i dont have a Skyline, but when i grad end of this year, i will be looking for a R34 GT-t so keep me posted if you know any good places to import a car...or if anyone is selling a black one.
Tokyo Extreme Racer aka Tokyo Highway Battle on the dreamcast is pretty cool but the GFX are absolute crap. Ive had it for a while on PS2 but had it years ago on DC which i reckon was better :P
Yeah inark....a lot of people say that
I have played TXR 2 on DC...TXR zero and 01 on PS2....when i first got 01...i thought the graphics sucked as well....but after a while i really liked it....especially when it is raining.
But you have to agree with me....you can make your car look mad..in da game
yeah looks ok but doesnt feel right but i spose it is an arcade based platform and the speeds are wrong... mine is in MPH even tho its doing KMH speeds and at 300mph it looks like ur doing about 80kmh :P
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
