  • Replies 250
I should be good to go for this guys :D.
I havn't got an oil cooler so if the oil temp creeps i'll just pull off the track and let her cool down.
+ will be a good chance to finally put some usernames & avatars to faces.
anything else i need to make sure ive done on the rb25 before i head out? catch can, oil cooler etc? its only got basic bolt ons and boosted turbo...
I don't think so mate.
People keep in mind you are only out there for 15 minutes hard driving at a time, that's it, it's not a 24 hour endurance race.
Not to mention that while you're out there, if someone spins out they wave the yellow flags, and you gotta go slow anyway, and someone is BOUND to spin out every round.
So your car actually does not actually go through that much punishment. If you went flat out in the hills from bottom to top it's the same sort of thing.
The only noticeable thing on my car was the brake fade. Brakes were not useless or anything, but effectiveness vastly diminished, and that was after 3 rounds, the last of which I used the brakes the most.
Just to put your minds at ease, when that happened and I couldn't slow down enough for a turn, I just drove straight, off the track, over some soft and squishy sand. No damage, no harm.
You will be able to hear/feel if something doesn't feel right and you can come off he track and have a look see.
how did you mange to get hold of those forms Brendan
could you please direct me in that direction
see attachments
Mallala_Drift_Practice_Form_P1.pdf
Mallala_Drift_Practice_Form_P2.pdf
Moodles please let me know of the gearbox flush sorts out the crunching issue, I know a guy who has complained of the same thing, you think the gearbox flush will sort it out?
on the track 3rd to 4th is normal to crunch on 32 gtrs (ive been told it will crunch no matter what gearbox fluid you have in there), just delay the shift an extra second and it wont crunch.. as for other crunches with other gears, good quality gearbox oil should help (shaun at boostworx has recommended to me redline's shockproof).
As for shift light, looking at a simple one, have my eye on the Gizzmo DSII (http://www.modyourcar.com.au/gizzmo-dsii-shiftlight-p5650)
paid off my seat this evening, ill be out there if i get that fitted in time. dont wanna spend my time out on the track driving like a habib cause i cant sit in a normal position with a helmet on...
Im looking at getting one of these shift lights, its not cheap but i think it better than just a single light. http://www.tunersgroup.com/Online_Store/Sh...ght_System.html
driving like that will improve your lap times by about 5 seconds there Dave
That shit light Chad is awesome mate
similar to what the F1 cars have
Edited by Krishy
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
