  • Replies 250
Tell us how the car feels after. That's my next suspension mod :/ front n back sway bars + rear strut brace... than i just gotta replace some bushes with nolathane ones and I'm set.
handling > horsepower.
+1
Especially on tight courses or hill climbs. My mates dad gets 36.8sec up Collingrove Hill Climb in a dead stock new clio with better suspension. Guys in Porches cant usually match that. But the guy has had years of experience on the same track so i guess "experience > money" counts too!
Got my slotted RDA rotors and qfm a1rm pads in finally!!
Bedding in was sketchy but after a good 30min drive, then going for the brakes hard again :) MASSIVE difference... im afraid to push it past half way, it just locks up regardless of speed. Gonna take a bit of getting used to for smooth quick braking but daaaammmnnn!!! Highly recommended.
Steel braded lines + master cyl stopper are next up then braking setup is finished.
Oh btw, since its track talk here, anyone know where I can get a decent cross bar for the r33? Its the bar that goes behind front seats used to bolt up the racing harnesses on to..
http://features.evolutionm.net/article.php?id=55
Edited by SkyHi_33
im jealous, i still have my slightly warped discs from the BSM cruise..also, if any1 could help me, is it ok to have a video camera strapped in with the use of duct tape? i would like to get some footage from the dash and im not sure if its allowed or not, i just want to make sure. Ah im so keen for this...first time track-user...
I cant wait for this, took the Skyline for a drive today for the first time in ages. Sort of forgot just how much 420rwhp throws ya back in ya seat :D
Edited by DSTROY
my car is slowly getting there. Needs all the new belts on and water pump, New tyres and then a wheel alignment.
gonna be a busy week.
yeah, i had the belt, tensioners, waterpump, radiator, hose done recently and im glad i did. can breathe a little better :D
just need to get me new pads and rear slotted rotors and the n1 turbos and my gearbox fitted and ill be laffin
-D
Im changing my engine oil n coolant tomorrow.
Does someone know who can service my auto trans cheap this week? I'm really low on cash and don't have the room to do the trans at my house.
Also, anyone got a 3"- 3.5" cat lying around cheap? I got the dump pipe ready to go in but would like to do the cat at the same time.
Cant wait for this!!
yeah, i had the belt, tensioners, waterpump, radiator, hose done recently and im glad i did. can breathe a little better :P
-D
Ben the pads we put in had plenty of life left in them so should be OK for awhile unless they're not pulling you up like you'd like.
IMO, for your use, slotted rear rotors = waste of money.
the pads do have more life but they dont bite anywhere near as hard as the bendix, and i really hate that.
just going to get the rear rotors at the same time i get q1fm pads, less hassle in the long run imho - slotted on all 4 = sexy too
-D
I hope you have a auto trans cooler for your auto box, i wouldn't take a auto car to a track without one
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
