  • Replies 250
Looks like great weather for a track day Sunday: http://www.weatherzone.com.au/sa/north-agricultural/mallala
Hopefully the same for skydiving as well, though I'll be there next open day, pretty much close to my Level 2 cams license
Sorry guys wont be able to make it out to this track day as the car needs a full service and prob a retune at the moment maybe next one
and goodluck to those who are going hope all goes well and stay off the walls
http://www.mallala.com/startyourengines/practice.html
2009
CARS & KARTS
Saturday 7th February
Saturday 4th April
Saturday 16th May
Saturday 27th June
Saturday 1st August
Saturday 5th September
Saturday 28th November
PRACTICE INSTRUCTIONS
sorry guys but since it is going to be raining according to the Roseworthy Weather station tomorrow i don't think it is going to be worth me going up and taking photos. :P
just because i am a nice guy :P. here is a shot i took at mallala last week for the drift practice......
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
