R32 GTR Parts, If you want it or need it please make an offer!!!
- Front Mount, GTR BOV, etc. (Average Condition)
- APEXi Struts (Adjustable)
- Complete Interior (Excellent Condition) (Front and Rear Seats, Panels, Anything u need just ask)
- Stock BN32GTR Turbo's, piping, Dump Pipe, etc.
Contact: Sam 0401723566
Edited by 7 Sins
Hey, I'm after a factory air box and factory piping from AFM's to turbos as well as factory piping from turbos to intercooler. You got any available and how much do you want? Can you do postage to melb?
Thanks...
Thanks...
Hey mate I will check through everything, I should have everything you need. let u know asap. thanks
Interior pics as requested.
hey do you have the rear quarter interior piece around the window (drivers side)?
Yes, have both of them.
hey mate ,how much are you after for the front seats.
Looking for around $700 but open to offers.
Thanks
What kind of condition is the interior panel like? How much you want for it posted to sydney?
Cheers!
  • 4 weeks later...
  • 1 year later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
