they are on fairly often.
we went to the one at Telstra Dome in January, it was pretty good (not set up very well) but had the cars on display and then inside had heaps of photographers (we are photographers so knew like everyone there!), also on display is cakes, stationery, gift ideas, fashion show of dresses and suits
and then in February we went to the one at the Exhibition Centre in Carlton, it was good, similar sort of stuff but nice and spaced out, more cars, different photographers, cakes etc and fashion show.
we also went to a venue expo for a particular caterer, that was really good.
most of the expos are advertised in the bridal magazines, does your fiance get any of them?
the expos are at the start of the year and then again mid year i think - http://www.bridalexpos.com.au/ and http://www.ourweddingexpos.com.au/vic.htm give you a bit of info
Thanks for that!
You mentioned you're a photographer, do you do weddings? :laugh:
She hasn't started getting mags yet, but it is about time we started!
hey dude.... congrats.. well, i work for a function venue as a chef, i am not promoting or anything.. it's just a gr8 place.. they got 3 venues like brighton, south yarra and ripponlea. give it a try.. and i think they have contacts for all yo needs like flowers and bla bla bla... link: http://www.gcholdings.com.au/.
i work in brighton ( the international). anything lemme know.
cheers
Edited by zippo
The International is good - my family have put on a fair few functions there, but being in Brighton if you have no other reasons to be in that part of town you dont want people making their way there if you are having the ceremony or majority of guests are all from elsewhere
There was a really nice wedding place somewhere in the Yarra Valley I think, I can't recall the name of the place its a fair way out of Melbourne, but great views, and some nice roads on the way :D
PM me if you want me to find the place, I cannot track it down in my email as it was about 2years ago....
Only problem is its a little hard to find and the carpark was gravel from memory.
There was a really nice wedding place somewhere in the Yarra Valley I think, I can't recall the name of the place its a fair way out of Melbourne, but great views, and some nice roads on the way ;)
Sebel Heritage?
- i went to a wedding there in November and it was beautiful
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
