looks like its an option on the JDM ones so if yours is JDM then its a dealer fit.
that said I'm digging through ADM and JDM FAST now for the correct bits :banana:
been asked to modify one of these cars and my intent is with OE bits.
questions - ask :banana:
https://www.sau.com.au/forums/topic/265086-reverse-camera-anyone/
will do. I have read all the threads on NAGTROC already and it looks like we have an advantage.
once I sort it I'll let everyone know :P
I'm making a call to tokyo in the morn to verify parts costs - if its not too scary (I'm used to buying parts on CPV35 versions) then I'll grab all the bits needed.
stay tuned.
ok camera is doable- anything you read on the NAGTROC site DOES NOT apply to this car. its entirely different underneath. I'm still trying to convince a local dealer who's not scared shitless of the main company to get me a ADM service manual for this car. I have the USDM one and I'm working on the JDM one.
at this stage the exercise using OEM GTR bits runs $1500 approx. aftermarket will be a LOT less but it will involve fiddling on my behalf to do it.
if anyone has tied with Nissan Oz I'm all ears..
  • 1 month later...
OOPS!!!
nissan's not going to like me - I modified one *just* a little bit.
one red GTR
(this is a MLB car and the owner's permission has been sought. I was flown down to do this car)
Stock System as it was set up by the owner
Navigation - local style .
Forget reworking the OEM system - its entirely different to the 370Z. I have proved that already. USDM is the same idea. second image is the inbuilt computer
Rear Camera
there is a front one as well tied to this.
Camera Locations:
Rear camera. you cannot see it but it can definitely see 1 meter back behind the car
Front Camera. visible from literal head on but not visible otherwise.
only image missing is the ipod unit and we did that as well.
A WARNING TO ALL WHO TINKER AND PULL THIS CAR APART!
this car will know if something has been pulled out - pulling the battery will not help- it will set flags. as it is I have to update my scan tool. this car had to go to nissan for a reset after all of this. for me it will not be a problem in the future.
want it done :
Melbourne
Stylyn Car Audio - Boronia
03-9739-8866 - Adam
www.stylyn.com
Brisbane
Audio Express
07-3256-7741
0407-102-839 - Chris
www.audioexpress.com.au
now who's game ?
Edited by Chris Rogers
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
