I had the exact same Fuel gear (700cc + 044 in tank + nismo reg) back in the day
Maxed out @ 365awkw @ CRD
You will definitely need to upgrade for 400awkw +
800cc will be fine.. I will be using them for 400rwkw no dramas. 700's will get near on 400 with a minor rail pressure increase
could have searched :P
http://www.skylinesaustralia.com/forums/In...wk-t264769.html
ok - i will upgrade my injectors to 800cc or more
how about my fuel pump, is it enough? i really dont want to run an external surge tank with an eloborate fuel system in the boot (just more reason for police to pick on me) as i want my setup to look as standard as possible
Even if you go for 1000cc injectors, the fuel pump will be the bottleneck.
To not run a surge tank in the boot there are a couple of options;
-Put the surge tank somewhere else
-Run the second pump intank (this is a bit of fu(king around though)
intank 044 and 800cc injectors made 430rwkw on my old gtr
intank 044 and 700cc made over 450rwkw in another gtr over here
just need to make sure your getting full voltage to fuel pump
that is interesting - i'll speak to my tuner tomorrow for confirmation
less headache for me if i kept my fuel system as is :P
Previous owner of my car maxed out 700 CC sards at 1.6 bar on GT RS's (I think) . Went to 800 CC sards and its fine.... Still using single in tank Nismo pump. Get the 800's! :) It might be worth throwing a fuel pressure gauge to make sure its staying rock solid up top.
Edited by Piggaz
I've got an external 044 and 700's with over 400rwkw, original tuner said it was unsafe (inj. duty cycle) and recommended I upgrade before hitting the track - second tuner said it was fine. Both are well respected so obviously your going to get different answers!
Personally I'd prefer the headroom and will be going bigger.
800cc injetors
023 intank bosch pump 800hp(new on the market) looks like the 040 with the filter on the bottom
and run new 1/2inch fuel lines (12.7mm)
and adj reg
maybe upgrade fuel rail
if that doesnt work. go for a 1200hp holly fuel pump with 1inch lines and 1000cc injetors :cool:
get ur setup right and u wont need a surge tank
I just bought 2 044's
But i have a tomei rail 800cc sards
and still need to buy a reg..
going to do a surge tank setup tho.
Dude, you NEED to see my car before you go down that path
have you guys had much to do with the bosch 1000cc injectors or better stick with sard?
i thought that bosch own sard?
siemens injectors, best spray pattern, no offence to every1 runing sards, but compared to siemens they are like a fire hydrant
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
