there's an apexi unit in the car atm, so no troubles with the main harness and plugging that in as its a direct replacement..
just cant find the two wires i need to splice onto from the handbrake..
can someone tell me how to get to these two wires and what they look like ?
any help is appreciated, cheers
https://www.sau.com.au/forums/topic/265278-greddy-turbo-timer/
If you do not connect these wires to the handbrake then turbo timer will not turn the engine off if the handbrake is disengage thus if some1 breaks into your car while the car is running by the turbo timer they can still drive the car(although the steering lock would engage)
if the turbo timer is set up with the alarm this step can be skipped
some alarm will automatically turn off the turbo timer if someone puts their foot on the acclerator or any other pedals for that matter.
But either way the steer lock will engage like it was mentioned above.
so i hooked it all up, aside from the park brake wire because i still cant find it, will try in daylight 2moro.
question for anyone using these, does yours beep every second it counts down? at the moment mine is, and inbetween displaying every second of the countdown, it shows [ S i D ] is this all just because its not recognising the brake as being applied and a warning?
Same.. i have a greddy turbo timer... no SiD here..
Sound can be turned off... show me a pic of your turbo timer and ill let you know if its the same as mine... As i have the manual for my turbo timer..
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
