^+1
Yes what Sheriff Wan said.
If you check it after the car has been driven / warmed up, the oil level will not be accurate.
Check it first thing in the morning is the best, so a cold engine.
^Yes thats right.
The oil must settle 1st.
If you read the oil dip stick while the engine is running, oil pressure will build up and again, oil will be all over the dip stick and you wont get s correct reading.
I agree with the guys, And I recommend oil to be checked first thing in the morning as the car hasn't been started for many hours. I even recommend that for changing oil so that all the oil is down the bottom. If gota do it after u been drinving the car than u must stop the car for at least 2 hours, or more if possible.
I don't agree.
hot dip it within 20 minutes of stopping the engine.
Remember that oil is viscous, therefore it 'expands' and 'contracts' under different temperatures - so it's probably ideal to check your oil when it's warm to simulate oil level when the engine is actually running.
So do I (disagree)!
You can check the oil level any time you like, as long as the engine isn't running, and the car is on level ground. If the engine has been running, leave it for as little as a minute before checking. After all, it's only a rough indication of oil quantity - it's either visible on the dipstick, or it's not. If it's visible, it's either high or it's low.
And always run the engine for a few minutes before changing the oil - the oil flows out much easier when it's warm.
Definitely doesn't take 2 hours for all your oil to drip/seep back to sump. 15-20 minutes if car has been driven and then when you've pulled the sump plug leave it out whilst you change filter and clean up, even go make yourself a coffee. I normally leave plug out for 20 minutes or more.
the skyline manual I have says to check the oil when the engine is at operating temperature and has been off for a few minutes.
for best results make sure the car is on level ground, pull the dipstick out and wipe it, then dip it again to check the level
I drop my oil when it is at operating temperature and let it drain for about 20 minutes to get as much of the old oil out.
just have to be quick moving your hand out of the way when undoing the sump plug, because naturally, hot oil burns like a bastard lol
Yeah you probably right, I just like being on the safe side, n wait a bit longer to let all the oil go down.
i always used an open spanner after undoing the sump plug with a socket.
takes a while for the hot oil to start dripping but when it does use the spanner and let it drop into the oil so you dont get 2nd degree oil burns.
make your tea as stated earlier then pour the oil into an old oil jug (remember you are not meant to bin it - recycle man) and grab the plug out or your drip tray when you can see it, wipe it with a rag and bung it back in there.
used to be able to cope tith hot oil but now i have girly office hands it burns like a bitch.
i also believe that oil levels should be checked at cold as this allows the oil to settle, and when adding oil you are not heating it up to operating temp before adding it. therefore factors such as heat and the expansion or retraction of oil variables are reduced. dip stick markings in my opinion would indicate the absolute reading at the period where conditions are least subject to variables such as oil in the motor and temp - ie ambient temp after the greatest portion of the oil has dropped to the sump.
my 2c :(
i cant believe it had to be asked, but spose better than not asking.
might i also add dean you should check it regularly. I check mine when i wash her usually as habit, along with coolant levels, washer bottle, power steer and glance over brake fluid etc. Its always better to check it before problems develop, coz its usually one of your first signs somethings going wrong.
Other than an automatic transmission and power steer almost every fluid on your car is DESIGNED to be checked cold. The dipstick is not designed to allow for heat expansion as its a poofteenth effect. WHY cold and after sitting for a while? Coz its a true reading as almost all the oil has dropped back to the engines sump.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
