Hey All,
I am going to paint my plenum black but it will mean my car will be off the road again (which is no good for me).
I thought I might buy a GReddy Plenum, get that painted and then swap it over in one day (I have to replace my knock sensors as well once the plenum is removed).
The question is, is it a worthwhile upgrade? My mod list is quite high:
Built/Forged 26
Arias Pistons
Argo Conrods
R33 GTR Crank
Balanced Bottom End
1.6mm Head Gasket
Jun 272 10.5mm Lift Cams
Tomei Cam Gears
Jun Oil Pump
N1 Water Pump
Trust Sump Extension
ATI Balancer
GReddy Pulley Kit
6 Boost Manifolds
GT2860-5's
Trust Dump/Front Extensions
Apexi PFC D-Jetro
Sard FPR, Rail, 800cc Injectors
Splitfire Coilpacks
Bosch 044
So maybe it will give me that extra flow.
Anyone here bought them and was happy/disappointed?
If it is not a worthwhile upgrade then I will just buy another stock plenum and paint that.
https://www.sau.com.au/forums/topic/265591-rb26-greddy-plenum-vs-stock-plenum/
Mate if I was you I would save your money and paint the std one.They get big power levels with the std plenum still in place.
You can spend the money to improve something else on the car.Why not just send the old plenum down to the painters early
in the morning.While your waiting for that to get painted you can change the knock sensors and what ever else you need to
do to the car in the meantime.I cant see why you cant get it done all in 1 day just have to be carefull not to chip the new
paint still maybe a bit soft but the painters should stick it in the oven for you though.
depends on what power your aiming for i think the stock plenums do alright /on par up until around the very high end lets say 500 kw then when your trying to squeeze your motor for everything go for a greddy one
Yeah...I dont know about that. I wouldnt.
The collectors can warp over time, I know mine was bent like a banana when I checked it, I wouldnt risk the 2 odd hours each way for a day or so of your car being off the road...
Better to keep the entire intake side in sets.
some of the fastest timeattack/circuit cars run single tb's. 1 explanation i've been given from the owners is that the std plenum/tb's flow approx 30% less than say a hypertune plenum/90mm tb, throttle response is as good if not better.
not to mention the std plenum is known to run leaner at the back than the front
Lag or less throttle response? Switching from a stock 25 intake to a stock 26 intake with ITB's and lost noticable low end due grunt to the short runners on the 26 intake. I think my friends home made short runner intake for his 25 with a Q45 has pretty snappy throttle response, even compared to mine. I think throttle response is kind of one of one of those over rated internet buzz words. It sounds real snappy blipping the throttle out of gear, and I get almost feedback when I hit the gas in gear, but I'm not sure how much faster I am.
Yes but its how the car "feels" as much as anything else.
A car that feels doughy and sloppy is not a good end user experience ;)
A car that feels nice and snappy, responsive is much more rewarding and fun.
Whilst over a 1/4 mile it might run the same time (under full load etc), but its driving around town where you appreciate a nice snappy feel like that.
I cant see how you could possibly have better throttle repsonse with a single TB compared to six smaller ones basically bolted straight to the ports in the head?
As for lean on one cylinder, most a/m plenums have the same problem anyway with distribution.
Has anyone driven a SR20 Silvia then driven a GTI-R straight after? Tell me you cant notice the difference...not power wise but response.
And you cant really compare a built 26 with std TBs which probably runs lower CR too. My car is slightly 'doughy' compared to a factory 26.
A car that feels doughy and sloppy is not a good end user experience :D
I can completely agree with that. :P I just wanted to throw out there that it is the particular effect everybody if chasing with these mods and all this effort, not more hp or better low end power. A lot of people out there confuse the two I think.
^^ ye and they also are not street driven.
Race cars, dedicated track cars, always bad examples.
As for the lean, that's simply and easily fixed with some minor correction/trim when getting tuned.
not street driven but throttle response and low end power delivery is almost everything. same as why most cars run low mount twins instead of big singles.
so ud rather have a poorly designed manifold and tune out the flaw? I'd rather have a proper manifold that flows evenly as possibly.
Id still like to see back to back flow tests.
Stock response? Id like to see that honestly! So far the single tb cars ive driven have had a noticible lag time
how was the heads setup on the different cars? did the different cars have the same tune? or did some ahve shitty fueld up tunes and some nice and crisp?
only the crap plenums that only look pretty have the shitty in-balance of flow, the proper ones are near perfect 1-6.
Who?
no1, i was having a dig :blink:
Stock heads both cars
Both tunes were freshish, cars both well taken care of with quality parts used
i bet both were 2.6's though, silly kents shoulda went 3.0, problem solvered
bit ot but i hate how 26's are down low, throttle responce mite be 'snappy' but theyve got n o t h i n g until about 4
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
