ive been around skylines for years...but this one was a little weird
r33 rb25det
SOUNDS like its running on 5 cylinders on idle
SOUNDS like its running on 5 cylinders when you go to take off and let the clutch out
at about 1500rpm BAM dissapears!!! and runs PEFECTLY
can run as much boost as you want ...rev to any limit or do anything you want
its like under 1000rpm to 1500rpm it sounds like its running on 5???
o2 sensor?
https://www.sau.com.au/forums/topic/265870-really-weird-problemany-help/
See what you've done, God! I warned you this would happen when you invented the O2 sensor - now the O2 sensor is the cause of every single problem in the modern EFI engine!
heyhey! - have you bothered to analyse which - if any - cylinder is misbehaving at low rpms? Have you checked that the VVT solenoid is working?
it used to run fine...but just sort of happened
i thought if it were plugs or coils...wouldnt it be doing it all the time?
BLIND ELK---- havnt found which cylinder...as it only runs on 5 when letting the clutch out... that tiny moment of initial take off
havnt checked the vvt solinoid will do that today
Edited by heyhey!
well until you workout which cyclinder is missing - no-one can help
Even then, once you FIX the once that is causing the problem, you'll find you dont have one anymore...
if i knew which cylinder was playing up IF ANY do u think id be posting here asking for anyones help???
i ask the question incase anyone else had been througha similar problem....
or for help from people that had ideas... not useless comments
as i said above....it SOUNDS like its running on 5 cylinders very breifly on take off...very very breifly though ( it may not even be running on 5 but sounds that way)
then runs unbelievably well for the rest of it
constructive ideas or people that have had a similar problem would be a great help
3lit3 32 ill look into this
Edited by heyhey!
Well how about you go and find out? Like i said...
your amazing...i went out and found it was cylinder 1....and now just like you said...its FIXED!!!... i didnt even have to touch anything!
NOT
what im getitng at if it is cylinder 1 ,2 ,3,4,5,6, what difference does it make if i have no idea what causing the problems
HENCE why i ask for opinions on THE problem...not which cylinder it is
for example ...oh that sound like an injector sticking problem i had in my old r32
example 2 ...oh that sounds like a dirty 02 sensor problem i had in my silvia
etc
Yeah you need to chill out a bit!!, hey hey!? is having a bit of trouble and is simply asking around for some advice and isn't that what this forum
is for!! yes maybe it is hard to give advise to hey hey, as there could be a number of reason for what it is doing but maybe some where to start would help instead of being a smart ass
+2 I'm with Punk72...
R31Nismoid, You usually have contructive ideas...bad day? :blink:
In regards to the problem, i'd suggest check your plugs first as it sounds like they may be fouling on idle then cleaning themselves as the revs go up. Also you may have the wrong heatrange...what plugs you using?
We can suggest generic solutions all day, but knowing which cylinder is important.
See if you can get access to someone with DataScan or equivalent & do a software-based power balance test at idle.
It may just be a dud plug, but do you really want to pull them all out, change them and still be wondering what the problem was?
Where are you located?
Hey let's not beat up on Nismoid here.
It is extremely important to know what cylinder a missfire is on. You simply cannot diagnose a missfire unless you know this.
It's a very valid statement to make as we are all here offering advice for days and days, using our own time, and after 5 days of rigorous testing you turn around and say 'oh I found the problem fellas, it was missfiring on cylinder one because there was a slightly broken wire in the injector plug at the terminal'
FUUUUUUUCK!!! - is what everyone says
If you are talking about some kind of shudder when you take off, could it be something silly like clutch shudder?
Also, if you have a valve seating problem, it will only be present at idle and the beginning of throttle (if the leak is tiny) but the missfire will definitely be there at idle.
Is it there from idle all the way up to 1000rpm? or is it fine at idle and just there once you try to take off?
see everyone is split
im saying if i knew which cylinder it is i wouldnt be posting ...i would have found the problem and fixed it the second it happened
you guys are saying find the cylinder and then u'll find the problem
im saying...ok its cylinder one! to solve this issue
now what would cause a car to miss under 1000rpm on cylinder one.....any ideas?
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
