ive been around skylines for years...but this one was a little weird
r33 rb25det
SOUNDS like its running on 5 cylinders on idle
SOUNDS like its running on 5 cylinders when you go to take off and let the clutch out
at about 1500rpm BAM dissapears!!! and runs PEFECTLY
can run as much boost as you want ...rev to any limit or do anything you want
its like under 1000rpm to 1500rpm it sounds like its running on 5???
o2 sensor?
https://www.sau.com.au/forums/topic/265870-really-weird-problemany-help/
See what you've done, God! I warned you this would happen when you invented the O2 sensor - now the O2 sensor is the cause of every single problem in the modern EFI engine!
heyhey! - have you bothered to analyse which - if any - cylinder is misbehaving at low rpms? Have you checked that the VVT solenoid is working?
it used to run fine...but just sort of happened
i thought if it were plugs or coils...wouldnt it be doing it all the time?
BLIND ELK---- havnt found which cylinder...as it only runs on 5 when letting the clutch out... that tiny moment of initial take off
havnt checked the vvt solinoid will do that today
Edited by heyhey!
well until you workout which cyclinder is missing - no-one can help
Even then, once you FIX the once that is causing the problem, you'll find you dont have one anymore...
if i knew which cylinder was playing up IF ANY do u think id be posting here asking for anyones help???
i ask the question incase anyone else had been througha similar problem....
or for help from people that had ideas... not useless comments
as i said above....it SOUNDS like its running on 5 cylinders very breifly on take off...very very breifly though ( it may not even be running on 5 but sounds that way)
then runs unbelievably well for the rest of it
constructive ideas or people that have had a similar problem would be a great help
3lit3 32 ill look into this
Edited by heyhey!
Well how about you go and find out? Like i said...
your amazing...i went out and found it was cylinder 1....and now just like you said...its FIXED!!!... i didnt even have to touch anything!
NOT
what im getitng at if it is cylinder 1 ,2 ,3,4,5,6, what difference does it make if i have no idea what causing the problems
HENCE why i ask for opinions on THE problem...not which cylinder it is
for example ...oh that sound like an injector sticking problem i had in my old r32
example 2 ...oh that sounds like a dirty 02 sensor problem i had in my silvia
etc
Yeah you need to chill out a bit!!, hey hey!? is having a bit of trouble and is simply asking around for some advice and isn't that what this forum
is for!! yes maybe it is hard to give advise to hey hey, as there could be a number of reason for what it is doing but maybe some where to start would help instead of being a smart ass
+2 I'm with Punk72...
R31Nismoid, You usually have contructive ideas...bad day? :blink:
In regards to the problem, i'd suggest check your plugs first as it sounds like they may be fouling on idle then cleaning themselves as the revs go up. Also you may have the wrong heatrange...what plugs you using?
We can suggest generic solutions all day, but knowing which cylinder is important.
See if you can get access to someone with DataScan or equivalent & do a software-based power balance test at idle.
It may just be a dud plug, but do you really want to pull them all out, change them and still be wondering what the problem was?
Where are you located?
Hey let's not beat up on Nismoid here.
It is extremely important to know what cylinder a missfire is on. You simply cannot diagnose a missfire unless you know this.
It's a very valid statement to make as we are all here offering advice for days and days, using our own time, and after 5 days of rigorous testing you turn around and say 'oh I found the problem fellas, it was missfiring on cylinder one because there was a slightly broken wire in the injector plug at the terminal'
FUUUUUUUCK!!! - is what everyone says
If you are talking about some kind of shudder when you take off, could it be something silly like clutch shudder?
Also, if you have a valve seating problem, it will only be present at idle and the beginning of throttle (if the leak is tiny) but the missfire will definitely be there at idle.
Is it there from idle all the way up to 1000rpm? or is it fine at idle and just there once you try to take off?
see everyone is split
im saying if i knew which cylinder it is i wouldnt be posting ...i would have found the problem and fixed it the second it happened
you guys are saying find the cylinder and then u'll find the problem
im saying...ok its cylinder one! to solve this issue
now what would cause a car to miss under 1000rpm on cylinder one.....any ideas?
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
