The Varex sounds perfect for you. Sound ON for fun and sound OFF for cops/missus. Have your pie and eat it too. Wish I got the varex.... awesome setup.
haha thats what my mrs says. I like it loud, tells the person next to me to watch out, lol. Just love the echoing noise in tunnels and the constant hum, e.t.c...
Ive got the varex. The note isnt as good as the others but at the touch of a button you hear nothing full on stealth mode. I love it..
ROFLMAO :stupid:
Absolutely love the Fujitsobo naming systems....
"Power Getter" to... get.... power
"Legalis" for being street legal
"Wagolis" for... wagons....
Their marketing manager needs to be promoted. Absolute gold.
If you're after off the shelf jap kits, I'd suggest a Fujitsubo Legalis Titanium. Nice exhaust note, not too loud/annoying.
did u end up getting 1??
im thinking hard about getting one...its tempting..
Of course matey :stupid:
I was a guinea pig of sorts... being I was the only one with a EPA lol.
Benno stuck with me and my many many failed EPA's, and a decent setup was reached that can be quiet when required for "legal" purposes, and near enough to legal on the street that most people shouldn't be hassled. Was a LOT of hair tearing involved... but worth it at the end of the day.
Thats coming from the 120dB exhaust i had before. I'm now the quietest car on SAU cruises, but I know ill flow 400rwkw :D
Ye two issue with the Varex
1. The exhaust note is shit
2. Its still EPA defectable.
Its adjustable. Nothing controllable by the owner/operator is legal like that. What's to stop you driving off and flicking a button? Nothing... hence its illegal.
Any adjustable flange/plate in the exhaust is illegal.
Any plate must be FULLY welded in, and not spot welded - fully round edge.
I really don't see any difference...
Your mega $ exhaust is 'near enough' to legal...near enough is not legal. So when it comes down to it, IF you get EPA'd, you have to modify it to pass. Now that may be a simple addition of an extra resonator etc, but it's still effort.
Now, your exhaust is quieter than most in its regular form, but so is a Varex when closed. So what's the difference? There isn't one. Both exhausts (a $400 muffler and your $1500-2k exhaust system) need to be modified to pass IF they are pulled up for testing.
If you have a Varex and drive around on the street with it closed for the most part, then chances are you won't get EPA'd, just as you'd not expect to with your system. But at the end of the day if you did get done, both require simple modification to pass, only one is a shit load cheaper.
So at the EPA station they would check for butterfly valves specifically?
If so, varex should make a full cat back with the RC butterfly valve somewhere much more upstream, so it's not detectable if you look at it from the back.
Near enough is good enough when your chasing power, you'll never get a 650hp street car totally legal. There is always compromise.
I would imagine for a RB, i reckon probably the closest in Victoria to legal for my power range :stupid:
The Varex also has the control over bypass in the main exhaust, this is also going to cause as restriction even when open. Plus it they make the car sound shit in my opinion.
Once you drive around for a week with the Varex in "quiet" mode you'll soon be leaving it fully open once you see just how restricting and unresponsive the car becomes... its such a pig you wont want to drive the car its literally that bad. So in the end you'll get EPA'd anyhow.
So this then makes the Varex something of a mission to pass. It requires fitment of a totally new muffler.
I you do the ole 2.25" pea shooter that is then noted on the EPA sheet... where as im noted down as a 3.5" so im infront there as i cant be questioned if i get a on-road EPA station
I actually want to test mine without any changes
I suspect the 92dB tester has a poorly calibrated meter based on the fact it was 92dB and the next day it pulled 86dB @ the other place in exactly the same format... so i wouldnt be surprised if all along I was getting shafted by the fked tester/setup and then thinking my exhaust wasn't legal, when in actual fact it might well have been :D
Phatboy - the restrictor needs to be right at the end. Having it up the front doesn't make much difference.
We've tested a similar set up. Its all about the noise @ the outlet between the last muffler and the tip
I don't think you're any safer with a Varex as I wasn't pulled over, it was likely an off duty cop on his way home because if I had've been up it... I have no doubt in my mind i would have been pulled over. So that means I would have been reported on "cruise" which is WELL below the EPA requirements.
That's the law though, you can be reported on suspicion, not fact.
I know for a fact that cruising around my car is quieter than 90dB. Its not until it climbs above 4500rpm that it gets over... and if i was even @ 4500rpm in 3rd I'd be in licence loss zone.
So the EPA I received was largely bullshit as most of them are because if i was 4500rpm under load in 3rd, i would have had the red and blue in my rear vision mirror
Overall i still class my exhaust better than anything I've seen yet, and the Varex is a worse option - not a same level one.
i just had my test, it came in at 94db but i wasnt very happy with the way the test was carried out considering it was a busy road and on the other side of that road was a tyre shop making alot of noise, and i had to pay $38 for something that took this guy under 5 mins to do the whole test. he was a very rude guy.
i think its near impossible to have a fast car and have the sound under 90db with these engines, i think they test them up to high in the rev range, the amount of times im that high is very rare im usually in traffic and you can barely hear mine. i can come home at night and not wake up my mum which is saying something cause she is a light sleeper lol.
You can have a quick skyline under 90db, the exhaust Ash is talking about is a 3.5 inch which will output monster power which is amazing how quite they are, I have herd a few and I am considering getting one myself as a 3inch just won't do.
I had a Fujitsubo exhaust (two oval mufflers) on my manual stagea which had 265 rwkw and was as quiet as stock on part accel, sure it was a little restrictive but until I really opened it up you cound ont even hear it, my mechanic even thought it had stalled at the lights it is so quiet that he tried to turn it over again while it was still running!!
It didnt have that destinctive RB rumble but I loved how quiet yet how powerful the car was. I think it all depends on your ultimate goal, if you are happy with the 250ish rwkw then it is possible to have a very quiet and legal exhaust but if you are wanting huge power then you have to pay for it and go for a Racepace style exhaust.
How much are the full GTR Racepace exhausts roughly? or even a cat back?
LOL.....$10 buxs he gets an off the shelf one..then gets a defect then gets a muffler replacement (1 and a half inch outlet type so he can pass .
But seriously...a well built custom job is the way to go.
I have a large resinator...kakimoto...and a large custom side entry muffler(great for any gtr)..3 1/2 inch stainless and
am way under 88db...lol
The muffler was made to fit the entire available area....a bit of weight...but I have no head aches anymore.
Should post up a pic.....
:) pics please :(
Of course matey :)
Thats coming from the 120dB exhaust i had before. I'm now the quietest car on SAU cruises, but I know ill flow 400rwkw :(
i know i will end up getting 1 from benno but probably towards the end of the year ... his so good at taking my money haha .. i need a damn good holiday where i can get mashed and pass out everyday on a beach somewhere so thats going to take priority now :(
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
