Hey peeps..
Its finally time to sell my house, ready to take off over to UK and to travel Europe.
I will add pics as soon as I can, having trouble uploading images on here atm...
Feel free to ask any questions or contact me if your are serious, although the sale will have to go through the real estate at this stage.
It is on the market at $310,000.
for enquiries contact me James on
Ph: 0448864649
email: [email protected]
or just PM me.. or post on this thread.
or Framptons realestate
here is the link to it on their website so you can see pics:
http://framptons.com.au/index.cfm?pagecall...SPRINGS_NT_0870
Some details:::
Colonial style charm greets you at the front, with a great old-style verandah.
Entry is to the living/dining area adjacent to a functional kitchen with plentiful cupboards and gas cooktops.
A conveniently located laundry leads outside to a beauty of a timber decked rear verandah.
The three bedrooms all feature built-in robes and ceiling fans. Bedrooms two and three would be great for kids while the main bedroom is a larger size with more extensive robes.
Gardening enthusiasts would greatly enjoy this house- the gardens are established and wouldn’t require much to turn this into your own personal Eden.
With plenty of space out the back and a garden shed for storage, you’ve got all you need.
There is also a handy carport out the front and a side access gate that allows vehicles into the rear.
Area Under Title: 807m2
Zoning: SD
Council Rates: $966 pa
Strata Fee: n/a
Rental: $330 - $350 pw
Lease Expiry: n/a
Easements: Sewerage Easement to PAWA
Year Built: 1989 (approx)
Thanks for your interest and please spread the word!!
Edited by Sklyn
https://www.sau.com.au/forums/topic/266021-property-for-sale-my-house-my-home/
cheers mate, and our rates just went up!!
council was good and kept rates down as long as possible to help encourage first home buyers etc..
We also don't have water restrictions at all, you just pay for the excess if you use it. Great for a desert!!
Go here to check out the neighbourhood!!
http://maps.google.com/maps?q=12_Patterson...sa=N&tab=il
Its a pretty good area.. in the 6 yrs I have lived here I have had very few problems, the neighbours have always been friendly and looked after the place when I was away. There are a number of police and prison guards living in the area and regular security patrols, so you can feel safe!
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
