really? i would have thought the mounting surface being closer to the centre of the wheel (where the load is spread more evenly each side) would have been beneficial.
2 points here, biggest cause of failure there is from harsh bumps in the road, not from cornering force, here the car sits static with almost always negative camber, this means staticly there is more force on the inside of the wheel, and when u hit a bump the suspension compresses, causing more dynamic negative camber, putting even more stress towards the inside of the wheel.
so if the stress here is put on the inside of the wheel, putting the mounting surface closer to the inside of the wheel, or at least closer to the middle, means the load is spread more evenly at the mounting surface, and there is less leverage.
Nisskid, agree with you that more stress may be caused by harsh bumps rather than cornering force since they are more dynamic and therefore require less force for failure - but not really sure since haven't measured it. Ive however heard of this type of failure happening more on the track (where u'd expect more cornering force) rather than on the street (where you'd expect more bumps) but could be wrong.
This failure is caused by the fact that putting an unsecured spacer on ur wheel changes the point at which the force hits the hub whilst not changing the point of bending. So where as the shear force is not larger, the bending moment will significantly increase and hence cause extra stress which will more likely result in shear failure. Here is the very rough diagram showing this:
Note the rectangles are the hubs not the wheels. The horizontal 5 lines are the wheel studs and the vertical line is where the wheel force is applied to the studs.
The letters in blue/red are forces and in black distances. Forces calculated assuming an applied force of x kN from the wheel.
Note that in this very rough sketch and i have approximated with the wheel load being a point load (x). As u increase the spacer size (from y to z) you get a linear increase in bending moment. In reality, this would be a distributed load, so the bending moment would really increase by a factor of the distance squared. ie if you x3 the distance, its x9 the bending moment.
Edited by Taso84
i think i get what ur trying to say, but it looks like ur talking about slip ons, not bolt on spacers? but yes, slip ons do add more leverage to the sheer force placed on the studs.
but i think if u look at the original post by mid life crisis, he simply refers to pushing the wheel out further, no reference to spacers, so im assuming he meant simply lowering the offset/increasing the track.
i personally wouldnt reccomend slip-on spacers any bigger than a few mm, the hub ring usually protrudes around 5mm, so unless ur using hubcentric slip ons (fairly rare) u lose ur hub at anything from about 4mm and over, and ur wheel is no longer hubcentric, that placed with the extra load we were talking about before, ur asking for trouble.
i run 3mm slip-on's to clear my breaks on the fronts...
i had custom spiggots machined up
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
