really? i would have thought the mounting surface being closer to the centre of the wheel (where the load is spread more evenly each side) would have been beneficial.
2 points here, biggest cause of failure there is from harsh bumps in the road, not from cornering force, here the car sits static with almost always negative camber, this means staticly there is more force on the inside of the wheel, and when u hit a bump the suspension compresses, causing more dynamic negative camber, putting even more stress towards the inside of the wheel.
so if the stress here is put on the inside of the wheel, putting the mounting surface closer to the inside of the wheel, or at least closer to the middle, means the load is spread more evenly at the mounting surface, and there is less leverage.
Nisskid, agree with you that more stress may be caused by harsh bumps rather than cornering force since they are more dynamic and therefore require less force for failure - but not really sure since haven't measured it. Ive however heard of this type of failure happening more on the track (where u'd expect more cornering force) rather than on the street (where you'd expect more bumps) but could be wrong.
This failure is caused by the fact that putting an unsecured spacer on ur wheel changes the point at which the force hits the hub whilst not changing the point of bending. So where as the shear force is not larger, the bending moment will significantly increase and hence cause extra stress which will more likely result in shear failure. Here is the very rough diagram showing this:
Note the rectangles are the hubs not the wheels. The horizontal 5 lines are the wheel studs and the vertical line is where the wheel force is applied to the studs.
The letters in blue/red are forces and in black distances. Forces calculated assuming an applied force of x kN from the wheel.
Note that in this very rough sketch and i have approximated with the wheel load being a point load (x). As u increase the spacer size (from y to z) you get a linear increase in bending moment. In reality, this would be a distributed load, so the bending moment would really increase by a factor of the distance squared. ie if you x3 the distance, its x9 the bending moment.
Edited by Taso84
i think i get what ur trying to say, but it looks like ur talking about slip ons, not bolt on spacers? but yes, slip ons do add more leverage to the sheer force placed on the studs.
but i think if u look at the original post by mid life crisis, he simply refers to pushing the wheel out further, no reference to spacers, so im assuming he meant simply lowering the offset/increasing the track.
i personally wouldnt reccomend slip-on spacers any bigger than a few mm, the hub ring usually protrudes around 5mm, so unless ur using hubcentric slip ons (fairly rare) u lose ur hub at anything from about 4mm and over, and ur wheel is no longer hubcentric, that placed with the extra load we were talking about before, ur asking for trouble.
i run 3mm slip-on's to clear my breaks on the fronts...
i had custom spiggots machined up
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
