  • Replies 356
Fresh update yet again!
  • GoldZilla; Nick; C34; Toongabbie; any day except Thursday night
  • Daleo, Dale, NM35, Emu Plains, Depends on the week, (Shiftworker)
  • Jetwreck, Craig, MN35 AR-X, Westleigh, Not Wednesday, Not at weeknight for the next 2 weeks, depends on soccer for the day on the weekend.
  • Bis-e Bee; Stephen; NM35; Blacktown; anytime, anyplace! :laugh:
  • Andy65b; Andy; NM35 AR-X; West Ryde; Not Thursday, Weekend in the afternoon, not this weekend.
  • ZEi250T, Iain, NM35 RX, Eastwooooooo, Whenever, wherever if the moneys right
  • Danny NM35 ARX glenorie, wat eve suits every1 :laugh: im pretty flexible cuz i aint married :banana:
  • Paramour, Julius, M35 AXIS, Northern Beaches, Sat night, anytime sunday
  • Crisis; Michael; ARX; Wahroonga; flexible
  • mxfly; Eugene; M35 AR-X; Wahroonga; anytime really.
  • CL11QE; Alex; C34; Riverstone; flexible
  • alu-siv_stagea, eddie, 99 rs four, botany, weekends (sunday better)
  • Charlie Stokes; C34; location unknown; flexible
  • CoastalChill/fat-lad; Kacey & Luke; C34; Newcastle; Sunday afternoon (someone suggested 4pm) sounds great!
  • inmate; John; C34; Blacktown; flexible
  • gebba54; Gerard; C34; Sutherland; Sundays preferred
  • too_much_boost; Anthony; location unknown; keen depending on time and location
  • Bikenut; Murray; M35 ARX; Helensburgh
  • StageIan; Ian; 99 RS4; Toongabbie; date as set
  • mike40sydney; Mike; C34 s2; Hassall Grove; date as set.
  • Angus Smart; Andrew; M35; location unknown; date as set, as long as the car is ready.
  • stagmeister; Jimmy; C34; "Western Sydney;" date as set, as long as the car is ready.
I'm rrrreeeaaalllllyyy looking forward to this!
Ben from North Shore Prestige may also be able to attend with a Stagea we may be interested to see.
Not definate yet but he is interested.
Cheers
Andy
lol... You going all "Danny" on us Andy?
Or do you only tell the people that definitely won't be there?
It's interesting but not that special. We spoke about it the other day. It will have trade plates.
Yes I know. But I figured those who do not know already may want to know.
So it is done?
Edited by iamhe77
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
