Ok today i was playing around with my father in laws new dynodynamics dyno, and hooked up the afr and boost sensors
did a power run, and noticed that at the top end the AFR's are around 14.4 : 1 ... this is too lean for 6000rpm full load ... so i tried a few things to see what the problem was as i think they should be more along the lines of 12.5 (its a s2 r33 gts-t with only a 3" catback as a mod)
i cleaned the afm... afr's still high....
so i did a fuel pressure test... and at the top end the fuel pressure was ~ 40psi .... is this right.. or should it be higher... because i have a feeling the pump may be on the way out and might not be delivering enough fuel!
any thoughts?
https://www.sau.com.au/forums/topic/266322-high-afrs-dead-pump/
lol @ friends comment.... pay me and you can use it :woot:
it made 141.7kw but i'm not concerned about power .... its the afr's im worried about... its just a stock standard Series 2 R33 gts-t with a 3" exhaust.. thats all.
i was asking about power because if it was over 180rwks or so i would say its time to upgrade fuel pump, but as its low power your stock fuel pump can easily handle it. might be playing up, or could be something else all together. im not sure what pressure it should be but ill be checking back on this topic to find out as im interested to know. good luck mate
i'm confused.. i hooked in a fuel pressure guage into the fuel line! ...... ran the car up on the dyno.. and at full boost/load at 6000rpm it was reading 40psi on the fuel pressure guage!
is that 40psi above manifold pressure or above atmo?
if manifold then thats right, if atmo then its too low
Ric - not married you douche, you know that, but easier way of explaining :P
Ash - plenty of juice is being provided on a platter for the fuel pump to take... and i think your right... 35-40 psi was base i thought. should increase with boost! i've got a new 040 sitting in my room just chillin out.. might throw that in.
Mat - yeah fuel filter was replaced 3 weeks ago when it was serviced... so would assume thats not an issue... yeah i was expecing around the 12 afr's on stardard tune ... but didnt think a std tune would be under 12! oh well..
got the rest of this week off work now... so will throw the 040 in tomorrow and dump it back on the dyno.. will keep everyone updated!
thanks guys
I had a similar issue, rich at idle and cruise, lean on boost. Turns out that the vacuum reference diaphram on the regulator had been destroyed, therefore keeping the fuel at base pressure and not following manifold pressure.
yer thats too low. should be 42psi (i think) base pressure then another psi for every psi of boost. so at 10psi fuel pressure should be 52psi.
had the same thing when my reg died, on boost it leaned out to the point where it simply couldnt fire, just spluttered.
with the stock ecu the AFR's usually drop into the 10s with higher than standard boost
daz you need to re wire the fuel pump wires all new ones do a search
Hey, thanks, have you had similar problems before? and that solved the problem?
im going to replace the fuel filter and getting a bosch fuel pump instead and earth it properly to see if it rectifies it
It was the Fuel pump that was causing the high afr's
put in a new bosch pump, and it fixed the issue!
here's the results for anyone interested
Thats good that the new pump solved the issue.
This is my graph, , notice the sudden spike in afr's in the lower graph.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
