Just had a new brand spanker gearbox installed last week, a late model R33 Pull type, into my early R32 GTR.
Was apparently easy as pie to swap the new box from pull, back to push.
Also at the time had the following done:
1. check & reseal transfer case, and attessa actuator, new transfer fluid (Motul synth ATF)
2. rebuilt tailshaft, rebuilt centre bearing and new CV at the rear, rebalance
3. rebuilt driveshaft from transfer case to front diff (2 joints)
4. new diff oil (Motul Gear Competition 75W140)
5. Castrol Syntrax 75W90 in the gearbox, as run-in for 500kms, then switching to Motul Gear 300 75W90
My question is this - when I first got the car, the rear diff would be clunky when you did low-speed high-lock driving - eg carparks.
I have not recently noticed this as much. Note that I have always had synth fluids in the gears and diffs and are changed regularly (less than 10,000kms).
Now that all the drivetrain is rebuilt or new, it seems to be clunky alot more. Is this a "good thing" in that it is all now tight? I'm guessing so.
The new box feels nice, but is still notchy. I guess that's what you get with an old agricultural box like these!
cheers
https://www.sau.com.au/forums/topic/266456-new-gearbox-installed-r32-gtr/
  • 1 month later...
Does the push type gear bolt straight in to the 33 Gear Box?
The reason that I ask is that I currently have the OS Giken pull to push converter in my 33 GTR as I used to have a OS Giken twin plate, I am looking at removing this and buying the 32 GTR push type components to install into my box to work with my new NPC twin plate that I am getting.
any help appreciated.
it may feel a lil bit notchy because ur clutch isnt adjusted properly i had the same thing with my gtst.... im unsure if gtr have adjustable pushrods from the clutch pedal but it may need just a lil extra travel added to the pedal cuz sumtimes u may be lazy and not push the pedal the whole way down.... just a suggestion see how it goes etc
IIRC the push or pull clutch is determined by the bellhousing, and you can swap bellhousings between gearboxes. Push is a backwards step and can be unreliable with a strong pressure plate spring - i think the pivot can break. You should be able to find this with searching, my memory is shot.
<snip>
I think you're going OTT with all this gear oil changing. The factory drain interval for 32 GTR is 100,000 on mineral oil. Synth should last three times that..... Syntrax is quality stuff.....
You could get your used oil analysed if you want some scientific corroboration of the above. Would cost less than a gearbox fill.
yep, you're probably right, Adam.
it's more just to make sure there is no machining swarf etc left in the new box
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
    • Yes, well. Mine are less than half that. ARBs are not set to "dumb" either.
    • I would hope. But, we all know even the best companies have an issue sporadically.
